[postgis-users] RESEND- Help with using Hibernate with PostGIS
Sandeep Kumar Jakkaraju sandeepkumar.jakkaraju at gmail.com
Sat Nov 18 05:34:41 PST 2006
Hi Norman
Please Help ..
This my class definition ...
public class RoadNetwork {
private Geometry location=null;
private long id;
public long getId()
return id;
public void setId(long id)
this.id = id;
public void setLocation(Geometry loc)
this.location = loc;
public Geometry getLocation()
return location;
My RoadNetwork.hbm.xml....
<!DOCTYPE hibernate-mapping PUBLIC
    "-//Hibernate/Hibernate Mapping DTD 3.0 //EN"
    "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping
    <class
        name="hello.RoadNetwork"
        table="Roads"
        <id
            name="id"
            column="id"
            type="java.lang.Long "
            <generator class="increment">
  </generator>
        </id>
        <property
            name="location"
            type=" org.postgis.hibernate.GeometryType"
            update="true"
            insert="true"
            column="location"
  </class>
</hibernate-mapping>
main method ..inserting in database...
 SessionFactory sessions = new
Configuration().configure().buildSessionFactory();
           session =sessions.openSession();
                        session.connection().setAutoCommit(true);
                        System.out.println("Inserting Record");
                        LineString geom = new LineString(lng_str);
                        RoadNetwork net = new RoadNetwork();
                        net.setLocation(geom);
                        session.save(net);
                        session.flush();
                        session.close();
                     System.out.println("Done");
Errors : I get
 [java] Hibernate: insert into Roads (location, id) values (?, ?)
     [java] 19:01:40,215  WARN JDBCExceptionReporter:71 - SQL Error: 0,
SQLState : null
     [java] 19:01:40,216 ERROR JDBCExceptionReporter:72 - Batch entry 0
insert i nto Roads (location, id) values (<stream of 105 bytes>, 1) was
aborted.  Call ge tNextException to see the cause.
     [java] 19:01:40,217  WARN JDBCExceptionReporter:71 - SQL Error: 0,
SQLState : 42804
     [java] 19:01:40,217 ERROR JDBCExceptionReporter:72 - ERROR: column
"locatio n" is of type oid but expression is of type bytea
     [java] 19:01:40,224 ERROR AbstractFlushingEventListener:300 - Could not
syn chronize database state with session
     [java] org.hibernate.exception.SQLGrammarException: Could not execute
JDBC batch update
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061118/2c3796d0/attachment.html>
