[postgis-users] postgis on fedora ...
Sandeep Kumar Jakkaraju sandeepkumar.jakkaraju at gmail.com
Sun Nov 26 10:58:28 PST 2006
Thanks Mike ...
I am sorry .. that i did not even check my results ...
I am able to do my work with INTERSECTS(geom,geom)...
but with CONTAINS(geom,geom) i dont get any results ..
If you want i can re post this in different thread !!??
Thanks
Regards
sandeep
On 11/26/06, Michael Fuhr <mike at fuhr.org> wrote:
> On Sun, Nov 26, 2006 at 11:21:03PM +0530, Sandeep Kumar Jakkaraju wrote:
> > Thanx for your reply ...but my geometry has 5 points ..
> > please see the attached file ..
> The polygons in the first half of the file (lines 1-48) don't have
> five points but rather five rings, each with one point.  The first
> one is:
> POLYGON((0 0),(280 0),(280 280),(0 280),(0 0))
> The polygons in the second half of the file (lines 49-96) appear
> to be duplicates of those in the first half, but with one ring of
> five points:
> POLYGON((0 0,280 0,280 280,0 280,0 0))
> > I get all the polygons for isvalid() and also for NOT isvalid() ...
> Are you sure?  Or are you getting the 48 good polygons (one ring
> of five points) for isvalid() and the 48 bad polygons (five rings
> of one point each) for NOT isvalid()?
> Michael Fuhr
> postgis-users mailing list
WeBlog:
http://jakkarajus.blogspot.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061127/1a2178d1/attachment.html>
