[postgis-users] PostGIS - hibernate (new postgis.jar)
Norman Barker nbarker at ittvis.com
Mon Nov 27 09:12:58 PST 2006
I think I missed the start of this thread (and I can't find it in the
archives), can you summarize the problem, and the server you are using?
The GeometryUserType class doesn't do very much but call out to the
utility functions provided in the postgis jar, so it does sound like a
classpath issue.
If you can send me a summary I will try to recreate the problem.  (I
have both tomcat and jboss set up here).
If the attachment is large please send it to norman.barker<at>gmail.com
Thanks,
Norman
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Jan
Syryn
Sent: 27 November 2006 16:39
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] PostGIS - hibernate (new postgis.jar)
Warning: Your file, postgis2.jar, contains more than 32 files after
decompression and cannot be scanned.
Hi Markus,
The thing I did to be able to continue is I have created a
postgis_addon.jar
lib that contained only new stuff like BinaryWriter.class and
GeometryUserType.
And that works. It does not solve the problem, though I can use the
latest
version of postgis.
I tried to use the tip I found in my previous posting by changing the
name
of the postgresql-jdbc.jar drvier to pg-jdbc.jar driver with my new
build
postgis2.jar (version 1.1.5)
I did not help.
If I remove the 2 stub files (PGConnection and Connection) from
postgis2.jar
: same result.
It stucks again on "No suitable driver".
If I replace the postgis2.jar by postgis.jar(1.1.0) and
postgis_addon.jar by
changing the settings on the classpath, everything works again.
So, I assume there is a thing in postgis2.jar.
And to create my postgis2.jar, I made a separate project in Eclipse,
created
a jar file of almost all java files(exl examples). This should do it, no
Anyway, I included my postgis2.jar so maybe one can replace his one with
mine and see what that does.
Or maybe one sees what I am doing wrong elsewhere...
TIA,
Jan
Markus
Schaber
Sent: samedi 25 novembre 2006 10:16
To: PostGIS Users Discussion
Subject: Re: [postgis-users] RE: RE: RE: PostGIS - hibernate - EJB3
Norman Barker wrote:
> 2. In the thread here, people are using:
> <driver-class>org.postgis.DriverWrapper</driver-class>
> When I do the same, I get a "No suitable driver" exception.
> 3. I wanted to use the GeometryType that is packed in PostGIS 1.1.5.
> After generating the new JAR and replacing the old one by this one, I
> start getting new exceptions:
> The class org.postgis.PGbox3d does not implement
> org.postgresql.util.PGobject.
Those 2 things look like a classpath/classloader problem.
You have to make sure that the postgis.jar and the postgresql-jdbc.jar
are
available via the same classloader (and that you don't have two
incarnations
of them in your classpath)
HTH,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
