[postgis-users] NOTICE: type "spheroid" is not yet defined
Frank Koormann frank.koormann at intevation.de
Tue Nov 28 06:24:10 PST 2006
Hi Christian,
* Christian.Strobl at dlr.de <Christian.Strobl at dlr.de> [061128 14:56]:
> hi all,
> i have compiled postgis 1.1.6 for ubuntu 6.06. at a first glance all
> worked fine but with
> psql -d mytestdb -f
> /usr/src/postgresql/postgresql-8.1.5/contrib/postgis-1.1.6/lwpostgis.sql
> i got the following messages (see below)
> is that anything i have to get worried about.
No, these notices are typical. You could issue a "make check" in the
PostGIS build directory to initially test the Build. Note that you must
have rights to create databases on the running postgresql server to do
so.
Best regards,
        Frank
Frank Koormann                             <frank.koormann at intevation.de>
 Professional Service around Free Software       (http://intevation.net/)
 FreeGIS Project                                 (http://freegis.org/)
 PostGIS Support (http://www.intevation.net/geospatial/postgis-support.en.html)
