[postgis-users] RE: zigGIS Usage Experiences
Abe Gillespie abe.gillespie at gmail.com
Tue Nov 28 10:55:15 PST 2006
Sorry, zigGIS does not write.  That, of course, is the "Holy Grail" of
these efforts.
-Abe
On 11/28/06, Paolo Corti <pcorti at gmail.com> wrote:
> Hello Joshua
> and thanks for the workaround, I will test it as ASAP
> It is very possibly that we could join to make some modification at ZigGis,
> as far as I would like in my spare time to write a connector for PostGis for
> ArcMap.
> First I was looking at PgArc (I also migrated that at ArcObjects 9), but I
> think the best approach is like ZigGis does, without a proxy shapefile, but
> directly reading the data.
> I have one more question, before going on.
> In this mailing list it was claimed, I think just from Abe, that ZigGis can
> read and also WRITE PostGis data. Is this correct? Because from what you are
> writing seems that ZigGis can just read and not write, and maybe I could be
> not interested in continuing using ZigGis.
> In fact I have decided to write in my spare time a full Read/Write PostGis
> connector for ArcMap. But before doing that I would like to deeply
> investigate if ZigGis already does the job.
> Best regards
> Paolo Corti
> http://www.paolocorti.net
> joshua.uyehara wrote:
> > Hey Paolo,
> > Abe isn't working on it anymore, but I have been occasionally plugging
> > away at it myself.  The problem with adding the layer in ArcMap is due
> > to a minor bug.
> > ZigGIS pulls the geometry column data from PostGIS in its native binary
> > format and passes it to ArcMap.  Unfortunately, PostGIS' internal binary
> > format is not identical to the expected wkb format, so ArcMap silently
> > ignores it and basically treats the table as a feature-less object
> > class.
> > One quick workaround is to create a view of the table that converts the
> > geometry column with asbinary(), and then manually add the necessary
> > entry to the geometry_columns table.
> > E.g.,
> > CREATE VIEW geom_table_view AS SELECT asbinary(geom_column) as
> > geom_column, column2, column3, FROM geom_table;
> > INSERT INTO geometry_columns (f_table_schema, f_table_name,
> > f_geometry_column, coord_dimension, srid, type) VALUES
> >       ('public', 'geom_table_view', 'geom_column', 2, -1,
> > 'MULTIPOLYGON');
> > Change schema, table, column names, srid, etc. to match your table, then
> > specify the view as the table to be opened with ZigGIS.  It's an ugly
> > kludge, but I haven't had the time to fix the problem in ZigGIS itself
> > yet.
> > Many of the feature class functionality hasn't been implemented yet, so
> > you can't do much besides display the features.  I'm planning to add
> > features to ZigGIS as I need them for work, but I can't give you any
> > timelines on it, as I'm swamped with other stuff at the moment.
> > Hope that helped,
> > Joshua Uyehara
> > joshua.uyehara at syngenta.com
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> > Paolo Corti
> > Sent: Monday, November 27, 2006 6:46 AM
> > To: postgis-users at postgis.refractions.net
> > Subject: Re: [postgis-users] zigGIS Usage Experiences
> > Hello Abe
> > you made a great job with your ZigGis! The ArcObjects code is amazing!
> > maybe you can give me a help
> > I compiled your code for using it with ArcGis 9 (i made some little
> > modifications at the code to get this) and .NET 2.0 It compiled fine,
> > but when I start ArcMap and I add a PostGIS layer, it adds the layer on
> > the TOC but nothing is showed/drawed on the map.
> > Looks like geometries are not read from the shape column.
> > I am wondering if you are still on this project, and maybe you could
> > give me some help, or if I am on my own and must deeply
> > investigate/debug myself the code in order to find what is not going
> > properly
> > best regards
> > Paolo Corti
> > GIS Developer
> > Abe Gillespie wrote:
> >> Sorry for the cross post, but the zigGIS list only has 9 subscribers
> >> with a ton more downloads than that.
> >> I'm curious about any experiences people are having using or even
> >> *trying* to use zigGIS.  Is it working?  Anyone need any help?  Any
> >> constructive criticism?  ... I haven't heard a peep yet.
> >> Thanks.
> >> -Abe
> >> _______________________________________________
> >> postgis-users mailing list
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> > View this message in context:
> > http://www.nabble.com/zigGIS-Usage-Experiences-tf696976.html#a7563276
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> View this message in context: http://www.nabble.com/zigGIS-Usage-Experiences-tf696976.html#a7585042
