[postgis-users] RE: zigGIS Usage Experiences
Paolo Corti pcorti at gmail.com
Wed Nov 29 01:09:17 PST 2006
Yes looks like a limit of custom layers, according to Esri docs
If you want to implement edit for custom layer looks like you have to
implement custom edit tool, there is a sample with xy file custom layer on
ArcObjects on line for implementing custom layer editing tool. Having said
that, from the other2 approaches: Plug in data source is read-only, so the
only viable solution would remain OGIS OLE DB Providers, but looks like it
is developable only with ATL c++
I recall the approaches here:
1) Custom Layers
2) Plug in data sources
3) OGIS compliant OLE DB providers
best regards
Paolo Corti
http://www.paolocorti.net
Abe Gillespie wrote:
> I agree.  And I even initially went down the route of a custom layer.
> I think it fell short right about when I started exploring editing
> capabilities ... IIRC it's not possible with a custom layer.  I also
> explored the OLEDB data source and that had its restrictions somewhere
> too.
> -Abe
> On 11/28/06, joshua.uyehara at syngenta.com <joshua.uyehara at syngenta.com>
> wrote:
>> Of all of the approaches so far, ZigGIS is the conceptually the
>> 'cleanest', as it is going the route of a full feature class adapter
>> implementation (the custom layer approach), but it also requires the
>> greatest amount of work, as you have to eventually implement the
>> functionality exposed by about a dozen interfaces.
>> pgArc is great for single users, but you run into problems when you need
>> concurrent access, or relationships with other tables in your database.
>> The same problems would plague the toolbox approach (which I assume
>> would basically be a front-end to shp2pgsql and pgsql2shp).
>> That's not to say that the pgArc or toolbox approaches aren't worth
>> pursuing.  They can probably meet some specific needs much faster than
>> ZigGIS will be able to.
>> Joshua Uyehara
>> Office: +1 808 337 1408 ext 34
>> Cell: +1 808 346 5185
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Bruce Rindahl
>> Sent: Tuesday, November 28, 2006 9:34 AM
>> To: 'PostGIS Users Discussion'
>> Cc: 'Shaun Kolomeitz'; 'Tyler Mitchell'
>> Subject: RE: [postgis-users] RE: zigGIS Usage Experiences
>> General discussion :)
>> I am using pgArc for my PostGIS/ArcMap connection.  It does both
>> read/write with some bugs.  I hope to post the changes to 9.x soon on
>> the pgArc site.
>> There is also another effort at:
>> http://datashare.gis.unbc.ca/transhape/
>> that uses a different approach.
>> I looked at zigGIS and passed only because I don't program in C#.
>> Finally, Would there be any interest in a ArcToolbox version of
>> PostGIS/ArcMap ??  I have done a lot of work on toolboxes and think I
>> could get a proof of concept going pretty soon.  Advantages would be
>> Python as a scripting language, the GUI is drag and drop and the tools
>> could be modular (One for read, one for append, one for update, etc).
>> No compiling would be necessary and the scripts could be used in Model
>> Builder.  Comments??
>> Bruce Rindahl
>> Paolo Corti
>> Sent: Tuesday, November 28, 2006 12:02 PM
>> To: postgis-users at postgis.refractions.net
>> Subject: Re: [postgis-users] RE: zigGIS Usage Experiences
>> Yes Abe
>> I have seen your 3ed at support.esri.com no one seemed to help you I am
>> sorry
>> Have you checked out these 3 alternatives at ArcObjects help (under
>> extending arcobjects)?
>> 1) Custom Layers
>> Plug in is not applicable (it is read only), but the other 2 are viable
>> Custom Layers also from .NET I was investigating if also OGIS OLE DB
>> could be developed in .NET (in the Help is written only VC++ realistic
>> for implementation, but maybe this comment is obsolete now)
>> in any case,
>> congratulations for your great job, even if ZigGis do not write ;-)
>> Paolo
>> > Sorry, zigGIS does not write.  That, of course, is the "Holy Grail" of
>> > these efforts.
>> > -Abe
>> > On 11/28/06, Paolo Corti <pcorti at gmail.com> wrote:
>> >> Hello Joshua
>> >> and thanks for the workaround, I will test it as ASAP It is very
>> >> possibly that we could join to make some modification at ZigGis, as
>> >> far as I would like in my spare time to write a connector for PostGis
>> >> for ArcMap.
>> >> First I was looking at PgArc (I also migrated that at ArcObjects 9),
>> >> but I think the best approach is like ZigGis does, without a proxy
>> >> shapefile, but directly reading the data.
>> >> I have one more question, before going on.
>> >> In this mailing list it was claimed, I think just from Abe, that
>> >> ZigGis can read and also WRITE PostGis data. Is this correct? Because
>> >> from what you are writing seems that ZigGis can just read and not
>> >> write, and maybe I could be not interested in continuing using
>> >> ZigGis.
>> >> In fact I have decided to write in my spare time a full Read/Write
>> >> PostGis connector for ArcMap. But before doing that I would like to
>> >> deeply investigate if ZigGis already does the job.
>> >> Best regards
>> >> Paolo Corti
>> >> joshua.uyehara wrote:
>> >> > Hey Paolo,
>> >> > Abe isn't working on it anymore, but I have been occasionally
>> >> > plugging away at it myself.  The problem with adding the layer in
>> >> > ArcMap is due to a minor bug.
>> >> > ZigGIS pulls the geometry column data from PostGIS in its native
>> >> > binary format and passes it to ArcMap.  Unfortunately, PostGIS'
>> >> > internal
>> >> binary
>> >> > format is not identical to the expected wkb format, so ArcMap
>> >> > silently ignores it and basically treats the table as a
>> >> > feature-less object class.
>> >> > One quick workaround is to create a view of the table that converts
>> >> > the geometry column with asbinary(), and then manually add the
>> >> > necessary entry to the geometry_columns table.
>> >> > E.g.,
>> >> > CREATE VIEW geom_table_view AS SELECT asbinary(geom_column) as
>> >> > geom_column, column2, column3, FROM geom_table; INSERT INTO
>> >> > geometry_columns (f_table_schema, f_table_name, f_geometry_column,
>> >> > coord_dimension, srid, type) VALUES
>> >> >       ('public', 'geom_table_view', 'geom_column', 2, -1,
>> >> > 'MULTIPOLYGON');
>> >> > Change schema, table, column names, srid, etc. to match your table,
>> >> then
>> >> > specify the view as the table to be opened with ZigGIS.  It's an
>> >> > ugly kludge, but I haven't had the time to fix the problem in
>> >> > ZigGIS itself yet.
>> >> > Many of the feature class functionality hasn't been implemented
>> >> > yet, so you can't do much besides display the features.  I'm
>> >> > planning to add features to ZigGIS as I need them for work, but I
>> >> > can't give you any timelines on it, as I'm swamped with other stuff
>> at the moment.
>> >> > Hope that helped,
>> >> > Joshua Uyehara
>> >> > Paolo Corti
>> >> > Sent: Monday, November 27, 2006 6:46 AM
>> >> > Subject: Re: [postgis-users] zigGIS Usage Experiences
>> >> > Hello Abe
>> >> > you made a great job with your ZigGis! The ArcObjects code is
>> amazing!
>> >> > maybe you can give me a help
>> >> > I compiled your code for using it with ArcGis 9 (i made some little
>> >> > modifications at the code to get this) and .NET 2.0 It compiled
>> >> > fine, but when I start ArcMap and I add a PostGIS layer, it adds
>> >> > the layer on the TOC but nothing is showed/drawed on the map.
>> >> > Looks like geometries are not read from the shape column.
>> >> > I am wondering if you are still on this project, and maybe you
>> >> > could give me some help, or if I am on my own and must deeply
>> >> > investigate/debug myself the code in order to find what is not
>> >> > going properly
>> >> > best regards
>> >> > Paolo Corti
>> >> > GIS Developer
>> >> >> Sorry for the cross post, but the zigGIS list only has 9
>> >> >> subscribers with a ton more downloads than that.
>> >> >> I'm curious about any experiences people are having using or even
>> >> >> *trying* to use zigGIS.  Is it working?  Anyone need any help?
>> >> >> Any constructive criticism?  ... I haven't heard a peep yet.
>> >> >> Thanks.
>> >> >> -Abe
>> >> >> _______________________________________________
>> >> >> postgis-users mailing list
>> >> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> >> > View this message in context:
>> >> > http://www.nabble.com/zigGIS-Usage-Experiences-tf696976.html#a75632
>> >> > 76 Sent from the PostGIS - User mailing list archive at Nabble.com.
>> >> http://www.nabble.com/zigGIS-Usage-Experiences-tf696976.html#a7585042
>> http://www.nabble.com/zigGIS-Usage-Experiences-tf696976.html#a7585331
View this message in context: http://www.nabble.com/zigGIS-Usage-Experiences-tf696976.html#a7595753
