[postgis-users] Intersection errors out with null directed edge
Rob Tester robtester at gmail.com
Thu Nov 30 16:12:19 PST 2006
This fixed some of the problems I still have other sets of geometries with
the same problem. Will know more tomorrow on which ones are causing the
problem.
Also the 3.0.0rc2 would not build for windows with MingW and Msys. It fails
with a link error. Building on Debian worked fine.
Rob.
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, November 30, 2006 10:51 AM
Subject: Re: [postgis-users] Intersection errors out with null directed edge
> On Wed, Nov 29, 2006 at 03:49:26PM -0700, Rob Tester wrote:
>> NOTICE:  AssertionFailedException: EdgeRing::computePoints: found null
>> Directed Edge
>> I have the following versions installed:
>> "POSTGIS="1.1.5" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
>> USE_STATS"
> GEOS 3.0.0 should many such cases, it's still in release candidate,
> but worth a try.
> --strk;
> postgis-users mailing list
