[postgis-users] unsubscribe
Adam adam at jamradar.com
Tue Oct 3 20:21:18 PDT 2006
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, October 03, 2006 8:16 AM
Subject: Re: [postgis-users] data base structure for holding climate data
> On Oct 2, 2006, at 10:22 AM, Obe, Regina wrote:
>> I would go with the single timestamp function datatype. Note - I think
>> you want timestamp instead of date if you plan to do anything with
>> hours
>> minutes and seconds, but otherwise date would be fine.
>> It's a lot more flexible when you are trying to aggregate data or
>> compare data over month, years, weeks, days, minutes etc. since you
>> can
>> then easily use the built-in postgres date functions.
>> I'm assuming also you will do the same for lat lon - store them as
>> postgis geom point types to take advantage of the postgis spatial
>> functions.
> Obe, How is storing lat lon as geom points different from reading
> them into postgis as simple xy coordinates?
> Thanks,
> Kirk
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Kirk
>> R. Wythers
>> Sent: Monday, October 02, 2006 11:11 AM
>> To: PostGIS Discussion Users
>> Subject: [postgis-users] data base structure for holding climate data
>> I am curious as to the consensus approach to handling dates in
>> postgis?
>> I have gathered up a fairly large collection of climate data. The date
>> fields however, came parsed in the form (year,month,day). I want to
>> set
>> up a postgres database to hold this data with a location structure
>> along
>> the lines of:
>> mn_climate=# \d sites
>>                  Table "public.sites"
>>       Column     |         Type          | Modifiers
>> site_id        | integer               |
>> site_shortname | character varying(8)  |
>> site_name      | character varying(50) |
>> lat            | numeric               |
>> lon            | numeric               |
>> utm_e          | numeric               |
>> utm_n          | numeric               |
>> Indexes:
>>      "sites_site_id_key" UNIQUE, btree (site_id)
>> And tie this "site" table to a second "clim" table that holds the
>> actual
>> meteorological data. However, I am inclined to concatenate the year,
>> month, day data into a single "date" data type of the form year-
>> month-day-hour-minute-second (yyyy-mm-dd-hh-mm-ss). Does this make
>> sense
>> to you all? If anyone can re-direct me before I do something dumb
>> in way
>> I set this up, I would appreciate it.
>> Thanks,
>> Kirk
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally
>> privileged and/or exempt from disclosure pursuant to Massachusetts
>> law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and
>> delete the material from any computer.
