[postgis-users] compiling postgis on solaris 10 fails with a core
Paul Ramsey pramsey at refractions.net
Tue Oct 10 15:04:54 PDT 2006
Since bison is coring out on you, maybe the first thing to try is a
newer version of bison?
http://ftp.gnu.org/pub/gnu/bison/
On 10-Oct-06, at 2:57 PM, Imre Oolberg wrote:
> Hallo!
> We are trying to implement PostGIS with PostgreSQL 8.1.4 on Solaris
> 10,
> Sparc platform but compiling (with GNU gcc) fails with the
> following message
> bash$ gmake
> gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.4"'
> -DPOSTGIS_VERSION='"1.1 USE_GEOS=0 USE_PROJ=0 USE_STATS=1"'
> -DPOSTGIS_SCRIPTS_VERSION='"1.1.4"' -DPOSTGIS_BUILD_DATE='"2006-10-10
> 21:38:35"' -I/usr/local/postgresql/include/server -DAUTOCACHE_BBOX=1
> -DUSE_STATS -Wall -g -O2 -fPIC -fexceptions    -c -o lwgparse.o
> lwgparse.c
> bison -y -vd -p lwg_parse_yy wktparse.y
> gmake[1]: *** [wktparse.tab.c] Segmentation Fault (core dumped)
> gmake[1]: Leaving directory `/opt/postgres/src/postgis-1.1.4/lwgeom'
> gmake: *** [liblwgeom] Error 2
> and pstack says
> bash:~/src/postgis-1.1.4$ pstack lwgeom/core
> core 'lwgeom/core' of 10098:    bison -y -vd -p lwg_parse_yy
> wktparse.y
>  000602bc ???????? (8c454, 100, 40, ffffffff, 3, ffbfc1a0)
>  00061030 quotearg_buffer (8c454, 100, 40, ffffffff, ffbfc1a0, 24)
> + 80
>  0006120c ???????? (0, 40, ffffffff, ffbfc1a0, 5b, 1)
>  00061464 quotearg_n_style (0, 3, 40, 6, ffbfc2b7, 7fffffe4) + 5c
>  00061544 quotearg_style (3, 40, 0, 80808080, 5b, 8e228) + 1c
>  000441c4 epilogue_augment (93328, ffbfd304, 6f, 94ccf, 94cd0, 1b)
> + 104
>  0003e8dc gram_parse (8c830, 77440, ffbff644, ffbff95e, 4a, 58) + 1afc
>  00045ae4 reader   (1, ffbffc74, ff3a0180, 6, ff36c1dc, ff34f7e0) +
> 22c
>  0002e504 main     (6, ffbffc74, ffbffc90, 89000, ff3a00c0,
> ff3a0100) + a4
>  00023c40 _start   (0, 0, 0, 0, 0, 0) + 108
> Before gmake was run './configure --prefix=/usr/local/postgis' in the
> following environment, no additional components are installed i.e.
> proj
> or geos
> bash:~/src/postgis-1.1.4$ env
> MANPATH=/usr/share/man:/opt/csw/man
> HZ=
> LC_MONETARY=et_EE.UTF-8
> SHELL=/bin/bash
> TERM=xterm
> LC_NUMERIC=et_EE.UTF-8
> OLDPWD=/opt/postgres/src
> LD_LIBRARY_PATH=/opt/csw/lib
> PAGER=/usr/bin/less
> MAIL=/var/mail/postgres
> PATH=/usr/local/postgresql/bin:/opt/csw/gcc3/bin:/opt/csw/bin:/usr/
> sfw/bin:/usr/dt/bin:/usr/openwin/bin:/usr/ccs/bin:/opt/csw/sbin:/
> usr/bin:
> LC_MESSAGES=C
> LC_COLLATE=et_EE.UTF-8
> PWD=/opt/postgres/src/postgis-1.1.4
> TZ=Europe/Tallinn
> PS1=\h:\w\$
> SHLVL=1
> HOME=/opt/postgres
> GCC=gcc
> LOGNAME=postgres
> LC_CTYPE=et_EE.UTF-8
> _=/usr/bin/env
> Within the same env we have successfully compiled postgresql and some
> other applications, too.
> If somebody could provide help on how to compile PostGIS on Solaris 10
> it would be very helpful!
> Imre
> postgis-users mailing list
