[postgis-users] [jdbc][datasource] use postgis through JDBC inSpring
Norman Barker nbarker at ittvis.com
Wed Oct 18 07:01:54 PDT 2006
Hi Nicolas,
I wrote a tutorial on doing this with PostGIS and EJB3 annotations (within JBoss) here - http://postgis.refractions.net/support/wiki/index.php?SpatialEJB3
It talks you through setting up a J2EE data source, and there is one the tutorial code.
I am currently looking at integrating ejbs (EJB3) and Lucene using annotations (already been done) with the aim of producing a catalog application based on PostGIS - again only using annotations.  PostGIS will allow the geographic search and Lucene will provide the text search of the entity beans.
I know it sounds as if I am reinventing GeoTools / GeoNetwork, I am not really I just need clustering, and annotations make life very easy (if a little harder to debug / follow!) and also the catalog needs to be LGPL if I am to use it.
Let me know if you need any help.
Norman
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Nicolas Delsaux
Sent: 18 October 2006 14:54
To: PostGIS Users Discussion
Subject: [postgis-users] [jdbc][datasource] use postgis through JDBC inSpring
Hi, is there anywhere a tutorial on PostGIS integration in JEE
environments using containers like Spring or, even simpler,
datasources instead of connections ?
I suspect geotools provides a layer for connection, but will it remove
the need for me to addDataTypes manually ?
Nicolas Delsaux
N'imprimez ce mail que si vous ne savez pas le lire sur l'écran : les
électrons se recyclent bien, le papier, beaucoup moins bien.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
