[postgis-users] PostGIS 1.1.5 Win32 Binaries for PostgreSQL 8.2 beta 1 available
TECHER David davidtecher at yahoo.fr
Sun Oct 22 06:02:48 PDT 2006
Hi Mike,
I have tried my own binaries on an other computer and installed it manually
runas /user:postgres cmd
set PATH=C:\Program Files\PostgreSQL\8.2beta1\bin;C:\Program
Files\PostgreSQL\8.2beta1\lib;%PATH%
set PGDATA=C:\Program Files\PostgreSQL\8.2beta1\data
initdb -A trust
createdb ....
and so on
it works
but I think it is a better idea to wait that postgresql 8.2 is out before
building it.
Perhaps I could try it for 8.1.5 if U want!
Let me know!
Mike Leahy a écrit :
>Thanks for the help David,
>Unfortunately, the same problem exists for me with the full binaries you
>just posted (that the liblwgeom.dll won't load) - plus I had to move
>libpq.dll from /lib folder to /bin.  Also, I'm pretty sure my earlier
>conclusions drawn from using the Dependency Walker were wrong, as it
>revealed similar dependency errors for a working installation that I
>have, so the problem must lie in my own configuration somehow.  Perhaps
>I'll give it another shot later, unless anyone has further suggestions...
>Thanks again,
>Mike
>TECHER David wrote:
>>Hi Mike
>>Thanks for your reply,
>>First of all, I spent a night in order to trying to build compil with
>>postgis
>>with the last snapshot from postgresql but without success :-( i.e.
>>ftp://ftp.fr.postgresql.org/binary/v8.2beta1/win32/
>>I've got the same error as you had i.e.
>>ERROR:  could not load library "D:/PSQL82/lib/liblwgeom.dll": The
>>specified module could not be found
>>Then since the last postgresql win32 installer was built from the
>>snapshot from
>>ftp://ftp.fr.postgresql.org/source/v8.2beta1/ then it worked but by
>>building everything
>>from source even for postgresql
>>I don't really not have any more info why...that's the first time I got
>>this error :-(
>>But I'm used to compil postgis on win32 only with restrict usage!
>>Hope someone has a idea how to solve it!!!
>>Else you can download all my binaries from this link
>>http://www.davidgis.fr/download/postgresql-8.2beta1-postgis-1.1.5-geos-2.2.3-proj-4.4.9.zip
>>(32 M)
>>For a manual installation the following link could be usefull
>>1) http://archives.postgresql.org/pgsql-hackers-win32/2005-07/msg00022.php
>>or
>>2) http://dev2dev.bea.com/pub/a/2005/05/intro_to_postgresql.html
>>!!! I HOPE SOMEONE HAS A BETTER IDEA!!!
>>>Hello list/David,
>>>I tried using these binaries with the PG 8.2 beta 1 windows binaries,
>>>and when I tried loading PostGIS, I got the following:
>>>postgres=# \i ../share/contrib/lwpostgis.sql
>>>BEGIN
>>>NOTICE:  type "histogram2d" is not yet defined
>>>DETAIL:  Creating a shell type definition.
>>>psql:../share/contrib/lwpostgis.sql:47: NOTICE:  type "histogram2d" is
>>>not yet defined
>>>specified module could not be found.
>>>psql:../share/contrib/lwpostgis.sql:47: ERROR:  could not load library
>>>"D:/PSQL82/lib/liblwgeom.dll": The specified module could not be found.
>>>ERROR:  current transaction is aborted, commands ignored until end of
>>>transaction block
>>>psql:../share/contrib/lwpostgis.sql:52: ERROR:  current transaction is
>>>aborted, commands ignored until end of transaction block
>>>transaction block
>>>etc....
>>>etc....
>>>etc....
>>>psql:../share/contrib/lwpostgis.sql:3685: ERROR:  current transaction is
>>>transaction block
>>>psql:../share/contrib/lwpostgis.sql:3732: ERROR:  current transaction is
>>>ROLLBACK
>>>postgres=#
>>>The library is definitely found at "D:/PSQL82/lib/liblwgeom.dll", so I
>>>checked using Dependency Walker, and it seems that the dll isn't linking
>>>to postgres.exe and liblwgeom_c-1.dll (both of which are in the bin
>>>folder).  I tried adding the bin folder to the PATH environment
>>>variable, but still no luck.  Any guesses?
>>>Thanks in advance for any suggestions,
>>>Mike
>>>TECHER David wrote:
>>>>Hi PostGISers,
>>>> PostGIS 1.1.5 is out!
>>>>[I am waiting  Marc does the installer ;-)]
>>>>!! BUT IT IS A TEMPORAY SOLUTION that I give you here!!
>>>>Since the postgis Win32 installer for 1.1.5 is not yet available, I've
>>>>built my own binaries
>>>>from postgresql 8.2beta1 for
>>>>* postgresql 8.2 beta1
>>>>*  geos 2.2.3 (As Paul said in a recent a mail, I'm agree with him for
>>>>the idea to wait before
>>>>                       building geos 3.0.0rc1 on win32 since it is in
>>>>dev version.)
>>>>* proj 4.4.9
>>>>* postgis 1.1.5
>>>>I've built it from the source which was used for the postgreql 8.2 beta1
>>>>available at
>>>>As Marc said and fixed the bug for MinGW (see his recent mail), all
>>>>regression test succeeded!
>>>>pgsql2shp too ;-) (thanks Marc)
>>>>INSTRUCTIONS:
>>>>POSTGREQL:
>>>>Install postgresql 8.2 beta1 o win32 from
>>>>it should be installed in "C:\Program Files\PostgreSQL\8.2beta1" by default
>>>>- !! INSTALL IT WITHOUT THE OPTIONAL POSTGIS !! -
>>>>POSTGIS:
>>>>U can download the binaries from here
>>>>http://www.davidgis.fr/download/win32/postgis-1.1.5/postgis-1.1.5-win32.zip
>>>>I don't try to build the java drivers (not enough times sorry!)
>>>>unzip it into "C:\Program Files\PostgreSQL\8.2beta1"
>>>>In order to creating a PostGIS Database called "testgis"
>>>>as postgres user do
>>>>createdb testgis
>>>>psql -d testgis -f C:\Program
>>>>Files\PostgreSQL\8.2beta1\share\contrib\lwpostgis.sql"
>>>>Files\PostgreSQL\8.2beta1\share\contrib\lspatial_ref_sys.sql"
>>>>I hope this instructions above will work for you ;-)
>>>>and Marc will have enough times to build the installer ;-)
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>--david;
--david;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061022/33e4261e/attachment.html>
