[postgis-users] Not able to excute spatial query on postgresql database with postgis support
vamsee movva vamseejump at gmail.com
Tue Oct 31 08:47:50 PST 2006
Hello Michael,
                    Thank you for reply. I never spotted that particular
query scanning 1139 rows, while others not.
Here i am furnishing the results of the questions you asked:
How big is that index?
I am sorry, i didn't under stand your question.(excuse me i am poor in
english).
How many rows are in la_damage?
 select count(*) from la_damage;
 count
 85017
(1 row)
What can you tell us about the geometries in la_damage ?
Honestly i don't have any idea about geometries and how to find geometries.
the geometry in la_blocks for stfid = 220750501002999?
I don't know how to see the geometry of the_geom column.
What's the output of the following query?
SELECT summary(the_geom) FROM la_blocks WHERE stfid = '220750501002999';
please find the attached file "stfid.txt"
Here i tried same query for one more stfid
SELECT summary(the_geom) FROM la_blocks WHERE stfid = '220750501002995';
 summary
MultiPolygon[B] with 1 elements
  Polygon[] with 2 rings
   ring 0 has 52 points
   ring 1 has 11 points
(1 row)
Is the query significantly faster with distance() = 0 instead of
intersects()?
>From my observation i think the query is significantly faster with
distance()=0 and returned more results than intersects().
What version of PostgreSQL are you running?
PostgreSQL 8.1.4 on x86_64-unknown-linux-gnu
I hope i gave you enough information, to help me.
Excuse me if i did any mistake in answering question.
Thanking you
vamsee movva
On 10/30/06, Michael Fuhr <mike at fuhr.org> wrote:
> On Mon, Oct 30, 2006 at 09:33:34AM -0600, vamsee movva wrote:
> > explain ANALYZE (select count(*) from la_blocks as c join la_damage as d
> on
> > c.stfid='220750501002999' and d.the_geom&&c.the_geom and intersects(
> > d.the_geom,c.the_geom));
> >        QUERY
> > PLAN
> > Aggregate  (cost=9.06..9.07 rows=1 width=0) (actual time=
> > 973892.916..973892.917 rows=1 loops=1)
> >   ->  Nested Loop  (cost=0.00..9.05 rows=1 width=0) (actual time=
> > 973892.901..973892.901 rows=0 loops=1)
> >         Join Filter: intersects("inner".the_geom, "outer".the_geom)
> >         ->  Index Scan using stfidx_la_blocks on la_blocks c  (cost=
> > 0.00..3.03 rows=1 width=585) (actual time=0.035..0.046 rows=1 loops=1)
> >               Index Cond: ((stfid)::text = '220750501002999'::text)
> >         ->  Index Scan using geomidx_la_damage on la_damage d  (cost=
> > 0.00..6.01 rows=1 width=21) (actual time=2018.848..44473.260 rows=1139
> > loops=1)
> >               Index Cond: (d.the_geom && "outer".the_geom)
> >               Filter: (d.the_geom && "outer".the_geom)
> > Total runtime: 973918.391 ms
> The index scan on geomidx_la_damage is taking a long time to find
> 1139 rows and then intersects() is taking forever to eliminate them
> all.  How big is that index?  How many rows are in la_damage?  What
> can you tell us about the geometries in la_damage and the geometry
> in la_blocks for stfid = 220750501002999?  What's the output of the
> following query?
> FROM la_blocks
> intersects()?  What version of PostgreSQL are you running?  What
> OS and hardware?  What non-default settings do you have in
> postgresql.conf?
> Michael Fuhr
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061031/6255a46d/attachment.html>
 summary
  Polygon[] with 2507 rings
   ring 0 has 1839 points
   ring 1 has 25 points
   ring 2 has 403 points
   ring 3 has 9 points
   ring 4 has 28 points
   ring 5 has 9 points
   ring 6 has 10 points
   ring 7 has 65 points
   ring 8 has 9 points
   ring 9 has 13 points
   ring 10 has 23 points
   ring 11 has 8 points
   ring 12 has 12 points
   ring 13 has 22 points
   ring 14 has 39 points
   ring 15 has 15 points
   ring 16 has 17 points
   ring 17 has 228 points
   ring 18 has 12 points
   ring 19 has 10 points
   ring 20 has 15 points
   ring 21 has 18 points
   ring 22 has 34 points
   ring 23 has 25 points
   ring 24 has 41 points
   ring 25 has 9 points
   ring 26 has 27 points
   ring 27 has 10 points
   ring 28 has 25 points
   ring 29 has 8 points
   ring 30 has 115 points
   ring 31 has 9 points
   ring 32 has 8 points
   ring 33 has 24 points
   ring 34 has 7 points
   ring 35 has 7 points
   ring 36 has 9 points
   ring 37 has 15 points
   ring 38 has 41 points
   ring 39 has 25 points
   ring 40 has 18 points
   ring 41 has 30 points
   ring 42 has 157 points
   ring 43 has 45 points
   ring 44 has 15 points
   ring 45 has 13 points
   ring 46 has 10 points
   ring 47 has 12 points
   ring 48 has 35 points
   ring 49 has 9 points
   ring 50 has 12 points
   ring 51 has 7 points
   ring 52 has 7 points
   ring 53 has 976 points
   ring 54 has 8 points
   ring 55 has 12 points
   ring 56 has 13 points
   ring 57 has 27 points
   ring 58 has 11 points
   ring 59 has 159 points
   ring 60 has 6 points
   ring 61 has 7 points
   ring 62 has 135 points
   ring 63 has 9 points
   ring 64 has 9 points
   ring 65 has 231 points
   ring 66 has 58 points
   ring 67 has 350 points
   ring 68 has 10 points
   ring 69 has 10 points
   ring 70 has 15 points
   ring 71 has 9 points
   ring 72 has 9 points
   ring 73 has 29 points
   ring 74 has 17 points
   ring 75 has 18 points
   ring 76 has 20 points
   ring 77 has 57 points
   ring 78 has 15 points
   ring 79 has 338 points
   ring 80 has 67 points
   ring 81 has 10 points
   ring 82 has 8 points
   ring 83 has 82 points
   ring 84 has 16 points
   ring 85 has 124 points
   ring 86 has 66 points
   ring 87 has 40 points
   ring 88 has 49 points
   ring 89 has 79 points
   ring 90 has 92 points
   ring 91 has 15 points
   ring 92 has 8 points
   ring 93 has 21 points
   ring 94 has 111 points
   ring 95 has 84 points
   ring 96 has 32 points
   ring 97 has 62 points
   ring 98 has 21 points
   ring 99 has 43 points
   ring 100 has 228 points
   ring 101 has 195 points
   ring 102 has 50 points
   ring 103 has 480 points
   ring 104 has 17 points
   ring 105 has 11 points
   ring 106 has 9 points
   ring 107 has 67 points
   ring 108 has 16 points
   ring 109 has 259 points
   ring 110 has 127 points
   ring 111 has 21 points
   ring 112 has 716 points
   ring 113 has 18 points
   ring 114 has 12 points
   ring 115 has 48 points
   ring 116 has 19 points
   ring 117 has 72 points
   ring 118 has 904 points
   ring 119 has 34 points
   ring 120 has 16 points
   ring 121 has 13 points
   ring 122 has 63 points
   ring 123 has 78 points
   ring 124 has 13 points
   ring 125 has 27 points
   ring 126 has 16 points
   ring 127 has 54 points
   ring 128 has 639 points
   ring 129 has 12 points
   ring 130 has 234 points
   ring 131 has 248 points
   ring 132 has 38 points
   ring 133 has 213 points
   ring 134 has 15 points
   ring 135 has 19 points
   ring 136 has 30 points
   ring 137 has 17 points
   ring 138 has 16 points
   ring 139 has 7 points
   ring 140 has 75 points
   ring 141 has 802 points
   ring 142 has 23 points
   ring 143 has 129 points
   ring 144 has 12 points
   ring 145 has 28 points
   ring 146 has 26 points
   ring 147 has 28 points
   ring 148 has 45 points
   ring 149 has 43 points
   ring 150 has 30 points
   ring 151 has 116 points
   ring 152 has 95 points
   ring 153 has 11 points
   ring 154 has 37 points
   ring 155 has 13 points
   ring 156 has 16 points
   ring 157 has 19 points
   ring 158 has 52 points
   ring 159 has 83 points
   ring 160 has 125 points
   ring 161 has 8 points
   ring 162 has 109 points
   ring 163 has 41 points
   ring 164 has 100 points
   ring 165 has 9 points
   ring 166 has 9 points
   ring 167 has 9 points
   ring 168 has 9 points
   ring 169 has 22 points
   ring 170 has 9 points
   ring 171 has 15 points
   ring 172 has 9 points
   ring 173 has 10 points
   ring 174 has 9 points
   ring 175 has 6 points
   ring 176 has 7 points
   ring 177 has 89 points
   ring 178 has 10 points
   ring 179 has 7 points
   ring 180 has 9 points
   ring 181 has 25 points
   ring 182 has 10 points
   ring 183 has 8 points
   ring 184 has 13 points
   ring 185 has 8 points
   ring 186 has 34 points
   ring 187 has 17 points
   ring 188 has 19 points
   ring 189 has 47 points
   ring 190 has 17 points
   ring 191 has 8 points
   ring 192 has 163 points
   ring 193 has 9 points
   ring 194 has 9 points
   ring 195 has 9 points
   ring 196 has 10 points
   ring 197 has 9 points
   ring 198 has 7 points
   ring 199 has 8 points
   ring 200 has 8 points
   ring 201 has 10 points
   ring 202 has 11 points
   ring 203 has 9 points
   ring 204 has 7 points
   ring 205 has 9 points
   ring 206 has 8 points
   ring 207 has 12 points
   ring 208 has 9 points
   ring 209 has 11 points
   ring 210 has 22 points
   ring 211 has 32 points
   ring 212 has 16 points
   ring 213 has 14 points
   ring 214 has 44 points
   ring 215 has 13 points
   ring 216 has 11 points
   ring 217 has 24 points
   ring 218 has 20 points
   ring 219 has 20 points
   ring 220 has 9 points
   ring 221 has 11 points
   ring 222 has 9 points
   ring 223 has 7 points
   ring 224 has 17 points
   ring 225 has 35 points
   ring 226 has 7 points
   ring 227 has 8 points
   ring 228 has 8 points
   ring 229 has 8 points
   ring 230 has 13 points
   ring 231 has 9 points
   ring 232 has 9 points
   ring 233 has 9 points
   ring 234 has 9 points
   ring 235 has 8 points
   ring 236 has 9 points
   ring 237 has 9 points
   ring 238 has 9 points
   ring 239 has 10 points
   ring 240 has 9 points
   ring 241 has 14 points
   ring 242 has 9 points
   ring 243 has 8 points
   ring 244 has 24 points
   ring 245 has 11 points
   ring 246 has 15 points
   ring 247 has 9 points
   ring 248 has 8 points
   ring 249 has 25 points
   ring 250 has 8 points
   ring 251 has 14 points
   ring 252 has 437 points
   ring 253 has 8 points
   ring 254 has 12 points
   ring 255 has 8 points
   ring 256 has 52 points
   ring 257 has 11 points
   ring 258 has 10 points
   ring 259 has 23 points
   ring 260 has 9 points
   ring 261 has 14 points
   ring 262 has 258 points
   ring 263 has 8 points
   ring 264 has 139 points
   ring 265 has 9 points
   ring 266 has 10 points
   ring 267 has 257 points
   ring 268 has 24 points
   ring 269 has 10 points
   ring 270 has 42 points
   ring 271 has 11 points
   ring 272 has 46 points
   ring 273 has 111 points
   ring 274 has 39 points
   ring 275 has 41 points
   ring 276 has 9 points
   ring 277 has 9 points
   ring 278 has 10 points
   ring 279 has 8 points
   ring 280 has 118 points
   ring 281 has 18 points
   ring 282 has 9 points
   ring 283 has 8 points
   ring 284 has 8 points
   ring 285 has 10 points
   ring 286 has 11 points
   ring 287 has 9 points
   ring 288 has 81 points
   ring 289 has 9 points
   ring 290 has 101 points
   ring 291 has 8 points
   ring 292 has 19 points
   ring 293 has 30 points
   ring 294 has 8 points
   ring 295 has 22 points
   ring 296 has 8 points
   ring 297 has 23 points
   ring 298 has 8 points
   ring 299 has 9 points
   ring 300 has 14 points
   ring 301 has 8 points
   ring 302 has 9 points
   ring 303 has 9 points
   ring 304 has 8 points
   ring 305 has 7 points
   ring 306 has 253 points
   ring 307 has 8 points
   ring 308 has 10 points
   ring 309 has 8 points
   ring 310 has 8 points
   ring 311 has 8 points
   ring 312 has 9 points
   ring 313 has 9 points
   ring 314 has 10 points
   ring 315 has 9 points
   ring 316 has 9 points
   ring 317 has 9 points
   ring 318 has 8 points
   ring 319 has 7 points
   ring 320 has 12 points
   ring 321 has 7 points
   ring 322 has 7 points
   ring 323 has 8 points
   ring 324 has 7 points
   ring 325 has 9 points
   ring 326 has 7 points
   ring 327 has 7 points
   ring 328 has 7 points
   ring 329 has 7 points
   ring 330 has 9 points
   ring 331 has 9 points
   ring 332 has 8 points
   ring 333 has 9 points
   ring 334 has 7 points
   ring 335 has 8 points
   ring 336 has 9 points
   ring 337 has 9 points
   ring 338 has 9 points
   ring 339 has 8 points
   ring 340 has 9 points
   ring 341 has 7 points
   ring 342 has 8 points
   ring 343 has 18 points
   ring 344 has 12 points
   ring 345 has 11 points
   ring 346 has 7 points
   ring 347 has 9 points
   ring 348 has 9 points
   ring 349 has 20 points
   ring 350 has 9 points
   ring 351 has 19 points
   ring 352 has 13 points
   ring 353 has 15 points
   ring 354 has 10 points
   ring 355 has 53 points
   ring 356 has 8 points
   ring 357 has 10 points
   ring 358 has 8 points
   ring 359 has 9 points
   ring 360 has 24 points
   ring 361 has 212 points
   ring 362 has 7 points
   ring 363 has 12 points
   ring 364 has 9 points
   ring 365 has 9 points
   ring 366 has 12 points
   ring 367 has 10 points
   ring 368 has 10 points
   ring 369 has 9 points
   ring 370 has 14 points
   ring 371 has 11 points
   ring 372 has 7 points
   ring 373 has 9 points
   ring 374 has 9 points
   ring 375 has 9 points
   ring 376 has 10 points
   ring 377 has 8 points
   ring 378 has 11 points
   ring 379 has 29 points
   ring 380 has 8 points
   ring 381 has 8 points
   ring 382 has 17 points
   ring 383 has 16 points
   ring 384 has 11 points
   ring 385 has 9 points
   ring 386 has 10 points
   ring 387 has 8 points
   ring 388 has 8 points
   ring 389 has 9 points
   ring 390 has 12 points
   ring 391 has 9 points
   ring 392 has 14 points
   ring 393 has 9 points
   ring 394 has 17 points
   ring 395 has 9 points
   ring 396 has 9 points
   ring 397 has 12 points
   ring 398 has 10 points
   ring 399 has 34 points
   ring 400 has 26 points
   ring 401 has 9 points
   ring 402 has 10 points
   ring 403 has 9 points
   ring 404 has 8 points
   ring 405 has 9 points
   ring 406 has 12 points
   ring 407 has 8 points
   ring 408 has 9 points
   ring 409 has 10 points
   ring 410 has 9 points
   ring 411 has 16 points
   ring 412 has 9 points
   ring 413 has 12 points
   ring 414 has 9 points
   ring 415 has 9 points
   ring 416 has 56 points
   ring 417 has 10 points
   ring 418 has 9 points
   ring 419 has 7 points
   ring 420 has 26 points
   ring 421 has 44 points
   ring 422 has 7 points
   ring 423 has 10 points
   ring 424 has 44 points
   ring 425 has 19 points
   ring 426 has 16 points
   ring 427 has 173 points
   ring 428 has 34 points
   ring 429 has 10 points
   ring 430 has 233 points
   ring 431 has 16 points
   ring 432 has 39 points
   ring 433 has 8 points
   ring 434 has 9 points
   ring 435 has 95 points
   ring 436 has 10 points
   ring 437 has 12 points
   ring 438 has 79 points
   ring 439 has 9 points
   ring 440 has 135 points
   ring 441 has 12 points
   ring 442 has 12 points
   ring 443 has 9 points
   ring 444 has 18 points
   ring 445 has 71 points
   ring 446 has 11 points
   ring 447 has 9 points
   ring 448 has 8 points
   ring 449 has 11 points
   ring 450 has 10 points
   ring 451 has 57 points
   ring 452 has 11 points
   ring 453 has 8 points
   ring 454 has 237 points
   ring 455 has 7 points
   ring 456 has 10 points
   ring 457 has 10 points
   ring 458 has 8 points
   ring 459 has 7 points
   ring 460 has 11 points
   ring 461 has 9 points
   ring 462 has 10 points
   ring 463 has 9 points
   ring 464 has 9 points
   ring 465 has 7 points
   ring 466 has 25 points
   ring 467 has 8 points
   ring 468 has 8 points
   ring 469 has 9 points
   ring 470 has 12 points
   ring 471 has 11 points
   ring 472 has 9 points
   ring 473 has 11 points
   ring 474 has 11 points
   ring 475 has 9 points
   ring 476 has 9 points
   ring 477 has 8 points
   ring 478 has 7 points
   ring 479 has 21 points
   ring 480 has 8 points
   ring 481 has 9 points
   ring 482 has 15 points
   ring 483 has 10 points
   ring 484 has 17 points
   ring 485 has 11 points
   ring 486 has 30 points
   ring 487 has 11 points
   ring 488 has 9 points
   ring 489 has 8 points
   ring 490 has 46 points
   ring 491 has 13 points
   ring 492 has 9 points
   ring 493 has 9 points
   ring 494 has 10 points
   ring 495 has 13 points
   ring 496 has 25 points
   ring 497 has 9 points
   ring 498 has 15 points
   ring 499 has 8 points
   ring 500 has 75 points
   ring 501 has 13 points
   ring 502 has 55 points
   ring 503 has 28 points
   ring 504 has 10 points
   ring 505 has 13 points
   ring 506 has 8 points
   ring 507 has 9 points
   ring 508 has 9 points
   ring 509 has 15 points
   ring 510 has 8 points
   ring 511 has 11 points
   ring 512 has 11 points
   ring 513 has 9 points
   ring 514 has 9 points
   ring 515 has 17 points
   ring 516 has 19 points
   ring 517 has 8 points
   ring 518 has 9 points
   ring 519 has 8 points
   ring 520 has 9 points
   ring 521 has 9 points
   ring 522 has 19 points
   ring 523 has 9 points
   ring 524 has 9 points
   ring 525 has 58 points
   ring 526 has 39 points
   ring 527 has 11 points
   ring 528 has 49 points
   ring 529 has 10 points
   ring 530 has 7 points
   ring 531 has 7 points
   ring 532 has 11 points
   ring 533 has 7 points
   ring 534 has 9 points
   ring 535 has 9 points
   ring 536 has 7 points
   ring 537 has 12 points
   ring 538 has 11 points
   ring 539 has 11 points
   ring 540 has 9 points
   ring 541 has 9 points
   ring 542 has 7 points
   ring 543 has 14 points
   ring 544 has 7 points
   ring 545 has 29 points
   ring 546 has 7 points
   ring 547 has 9 points
   ring 548 has 10 points
   ring 549 has 8 points
   ring 550 has 7 points
   ring 551 has 9 points
   ring 552 has 10 points
   ring 553 has 7 points
   ring 554 has 7 points
   ring 555 has 9 points
   ring 556 has 8 points
   ring 557 has 9 points
   ring 558 has 7 points
   ring 559 has 8 points
   ring 560 has 7 points
   ring 561 has 10 points
   ring 562 has 9 points
   ring 563 has 6 points
   ring 564 has 12 points
   ring 565 has 9 points
   ring 566 has 8 points
   ring 567 has 12 points
   ring 568 has 11 points
   ring 569 has 14 points
   ring 570 has 29 points
   ring 571 has 6 points
   ring 572 has 14 points
   ring 573 has 287 points
   ring 574 has 16 points
   ring 575 has 9 points
   ring 576 has 25 points
   ring 577 has 17 points
   ring 578 has 259 points
   ring 579 has 21 points
   ring 580 has 12 points
   ring 581 has 13 points
   ring 582 has 13 points
   ring 583 has 10 points
   ring 584 has 12 points
   ring 585 has 10 points
   ring 586 has 36 points
   ring 587 has 55 points
   ring 588 has 9 points
   ring 589 has 11 points
   ring 590 has 12 points
   ring 591 has 18 points
   ring 592 has 12 points
   ring 593 has 11 points
   ring 594 has 34 points
   ring 595 has 10 points
   ring 596 has 7 points
   ring 597 has 14 points
   ring 598 has 13 points
   ring 599 has 9 points
   ring 600 has 11 points
   ring 601 has 19 points
   ring 602 has 10 points
   ring 603 has 49 points
   ring 604 has 9 points
   ring 605 has 8 points
   ring 606 has 92 points
   ring 607 has 11 points
   ring 608 has 23 points
   ring 609 has 9 points
   ring 610 has 17 points
   ring 611 has 12 points
   ring 612 has 99 points
   ring 613 has 139 points
   ring 614 has 10 points
   ring 615 has 35 points
   ring 616 has 79 points
   ring 617 has 8 points
   ring 618 has 9 points
   ring 619 has 7 points
   ring 620 has 9 points
   ring 621 has 23 points
   ring 622 has 12 points
   ring 623 has 48 points
   ring 624 has 7 points
   ring 625 has 12 points
   ring 626 has 17 points
   ring 627 has 11 points
   ring 628 has 9 points
   ring 629 has 8 points
   ring 630 has 84 points
   ring 631 has 10 points
   ring 632 has 9 points
   ring 633 has 68 points
   ring 634 has 55 points
   ring 635 has 11 points
   ring 636 has 32 points
   ring 637 has 21 points
   ring 638 has 12 points
   ring 639 has 256 points
   ring 640 has 9 points
   ring 641 has 58 points
   ring 642 has 38 points
   ring 643 has 8 points
   ring 644 has 9 points
   ring 645 has 10 points
   ring 646 has 13 points
   ring 647 has 18 points
   ring 648 has 13 points
   ring 649 has 64 points
   ring 650 has 9 points
   ring 651 has 9 points
   ring 652 has 14 points
   ring 653 has 10 points
   ring 654 has 9 points
   ring 655 has 11 points
   ring 656 has 9 points
   ring 657 has 8 points
   ring 658 has 14 points
   ring 659 has 9 points
   ring 660 has 48 points
   ring 661 has 8 points
   ring 662 has 15 points
   ring 663 has 10 points
   ring 664 has 8 points
   ring 665 has 8 points
   ring 666 has 10 points
   ring 667 has 14 points
   ring 668 has 8 points
   ring 669 has 10 points
   ring 670 has 9 points
   ring 671 has 17 points
   ring 672 has 18 points
   ring 673 has 9 points
   ring 674 has 85 points
   ring 675 has 11 points
   ring 676 has 19 points
   ring 677 has 7 points
   ring 678 has 8 points
   ring 679 has 9 points
   ring 680 has 77 points
   ring 681 has 12 points
   ring 682 has 9 points
   ring 683 has 8 points
   ring 684 has 13 points
   ring 685 has 8 points
   ring 686 has 16 points
   ring 687 has 37 points
   ring 688 has 163 points
   ring 689 has 8 points
   ring 690 has 10 points
   ring 691 has 10 points
   ring 692 has 16 points
   ring 693 has 22 points
   ring 694 has 10 points
   ring 695 has 13 points
   ring 696 has 11 points
   ring 697 has 9 points
   ring 698 has 11 points
   ring 699 has 10 points
   ring 700 has 10 points
   ring 701 has 9 points
   ring 702 has 17 points
   ring 703 has 12 points
   ring 704 has 16 points
   ring 705 has 16 points
   ring 706 has 25 points
   ring 707 has 13 points
   ring 708 has 54 points
   ring 709 has 11 points
   ring 710 has 25 points
   ring 711 has 10 points
   ring 712 has 11 points
   ring 713 has 20 points
   ring 714 has 40 points
   ring 715 has 9 points
   ring 716 has 9 points
   ring 717 has 19 points
   ring 718 has 18 points
   ring 719 has 13 points
   ring 720 has 30 points
   ring 721 has 9 points
   ring 722 has 10 points
   ring 723 has 10 points
   ring 724 has 153 points
   ring 725 has 16 points
   ring 726 has 9 points
   ring 727 has 25 points
   ring 728 has 16 points
   ring 729 has 12 points
   ring 730 has 9 points
   ring 731 has 16 points
   ring 732 has 8 points
   ring 733 has 13 points
   ring 734 has 10 points
   ring 735 has 43 points
   ring 736 has 201 points
   ring 737 has 9 points
   ring 738 has 17 points
   ring 739 has 9 points
   ring 740 has 9 points
   ring 741 has 13 points
   ring 742 has 14 points
   ring 743 has 25 points
   ring 744 has 15 points
   ring 745 has 50 points
   ring 746 has 24 points
   ring 747 has 12 points
   ring 748 has 8 points
   ring 749 has 10 points
   ring 750 has 12 points
   ring 751 has 18 points
   ring 752 has 103 points
   ring 753 has 8 points
   ring 754 has 10 points
   ring 755 has 46 points
   ring 756 has 9 points
   ring 757 has 9 points
   ring 758 has 9 points
   ring 759 has 9 points
   ring 760 has 9 points
   ring 761 has 11 points
   ring 762 has 7 points
   ring 763 has 8 points
   ring 764 has 10 points
   ring 765 has 9 points
   ring 766 has 14 points
   ring 767 has 17 points
   ring 768 has 8 points
   ring 769 has 17 points
   ring 770 has 9 points
   ring 771 has 9 points
   ring 772 has 22 points
   ring 773 has 9 points
   ring 774 has 9 points
   ring 775 has 14 points
   ring 776 has 11 points
   ring 777 has 17 points
   ring 778 has 12 points
   ring 779 has 11 points
   ring 780 has 9 points
   ring 781 has 12 points
   ring 782 has 11 points
   ring 783 has 7 points
   ring 784 has 8 points
   ring 785 has 10 points
   ring 786 has 251 points
   ring 787 has 8 points
   ring 788 has 19 points
   ring 789 has 31 points
   ring 790 has 40 points
   ring 791 has 9 points
   ring 792 has 8 points
   ring 793 has 10 points
   ring 794 has 9 points
   ring 795 has 10 points
   ring 796 has 9 points
   ring 797 has 10 points
   ring 798 has 8 points
   ring 799 has 8 points
   ring 800 has 8 points
   ring 801 has 9 points
   ring 802 has 8 points
   ring 803 has 24 points
   ring 804 has 9 points
   ring 805 has 84 points
   ring 806 has 18 points
   ring 807 has 10 points
   ring 808 has 13 points
   ring 809 has 8 points
   ring 810 has 11 points
   ring 811 has 9 points
   ring 812 has 9 points
   ring 813 has 9 points
   ring 814 has 39 points
   ring 815 has 7 points
   ring 816 has 17 points
   ring 817 has 9 points
   ring 818 has 9 points
   ring 819 has 69 points
   ring 820 has 39 points
   ring 821 has 10 points
   ring 822 has 7 points
   ring 823 has 10 points
   ring 824 has 8 points
   ring 825 has 29 points
   ring 826 has 9 points
   ring 827 has 7 points
   ring 828 has 11 points
   ring 829 has 18 points
   ring 830 has 21 points
   ring 831 has 9 points
   ring 832 has 11 points
   ring 833 has 16 points
   ring 834 has 7 points
   ring 835 has 13 points
   ring 836 has 10 points
   ring 837 has 10 points
   ring 838 has 11 points
   ring 839 has 11 points
   ring 840 has 36 points
   ring 841 has 14 points
   ring 842 has 23 points
   ring 843 has 11 points
   ring 844 has 10 points
   ring 845 has 9 points
   ring 846 has 10 points
   ring 847 has 9 points
   ring 848 has 8 points
   ring 849 has 8 points
   ring 850 has 10 points
   ring 851 has 9 points
   ring 852 has 26 points
   ring 853 has 13 points
   ring 854 has 10 points
   ring 855 has 10 points
   ring 856 has 8 points
   ring 857 has 36 points
   ring 858 has 13 points
   ring 859 has 1619 points
   ring 860 has 10 points
   ring 861 has 8 points
   ring 862 has 103 points
   ring 863 has 14 points
   ring 864 has 13 points
   ring 865 has 7 points
   ring 866 has 29 points
   ring 867 has 23 points
   ring 868 has 10 points
   ring 869 has 9 points
   ring 870 has 9 points
   ring 871 has 15 points
   ring 872 has 9 points
   ring 873 has 223 points
   ring 874 has 9 points
   ring 875 has 7 points
   ring 876 has 12 points
   ring 877 has 206 points
   ring 878 has 14 points
   ring 879 has 9 points
   ring 880 has 30 points
   ring 881 has 32 points
   ring 882 has 9 points
   ring 883 has 61 points
   ring 884 has 8 points
   ring 885 has 38 points
   ring 886 has 16 points
   ring 887 has 17 points
   ring 888 has 17 points
   ring 889 has 9 points
   ring 890 has 8 points
   ring 891 has 11 points
   ring 892 has 9 points
   ring 893 has 18 points
   ring 894 has 9 points
   ring 895 has 10 points
   ring 896 has 26 points
   ring 897 has 26 points
   ring 898 has 56 points
   ring 899 has 7 points
   ring 900 has 16 points
   ring 901 has 9 points
   ring 902 has 10 points
   ring 903 has 9 points
   ring 904 has 9 points
   ring 905 has 30 points
   ring 906 has 9 points
   ring 907 has 24 points
   ring 908 has 9 points
   ring 909 has 20 points
   ring 910 has 11 points
   ring 911 has 10 points
   ring 912 has 201 points
   ring 913 has 13 points
   ring 914 has 27 points
   ring 915 has 11 points
   ring 916 has 9 points
   ring 917 has 8 points
   ring 918 has 10 points
   ring 919 has 15 points
   ring 920 has 12 points
   ring 921 has 10 points
   ring 922 has 7 points
   ring 923 has 10 points
   ring 924 has 15 points
   ring 925 has 9 points
   ring 926 has 39 points
   ring 927 has 10 points
   ring 928 has 22 points
   ring 929 has 12 points
   ring 930 has 9 points
   ring 931 has 9 points
   ring 932 has 10 points
   ring 933 has 8 points
   ring 934 has 9 points
   ring 935 has 10 points
   ring 936 has 62 points
   ring 937 has 10 points
   ring 938 has 8 points
   ring 939 has 9 points
   ring 940 has 10 points
   ring 941 has 38 points
   ring 942 has 89 points
   ring 943 has 67 points
   ring 944 has 87 points
   ring 945 has 31 points
   ring 946 has 11 points
   ring 947 has 61 points
   ring 948 has 10 points
   ring 949 has 15 points
   ring 950 has 13 points
   ring 951 has 17 points
   ring 952 has 11 points
   ring 953 has 41 points
   ring 954 has 44 points
   ring 955 has 20 points
   ring 956 has 10 points
   ring 957 has 30 points
   ring 958 has 16 points
   ring 959 has 46 points
   ring 960 has 12 points
   ring 961 has 8 points
   ring 962 has 11 points
   ring 963 has 11 points
   ring 964 has 20 points
   ring 965 has 75 points
   ring 966 has 9 points
   ring 967 has 87 points
   ring 968 has 9 points
   ring 969 has 297 points
   ring 970 has 12 points
   ring 971 has 8 points
   ring 972 has 9 points
   ring 973 has 15 points
   ring 974 has 19 points
   ring 975 has 7 points
   ring 976 has 14 points
   ring 977 has 24 points
   ring 978 has 17 points
   ring 979 has 11 points
   ring 980 has 9 points
   ring 981 has 84 points
   ring 982 has 361 points
   ring 983 has 9 points
   ring 984 has 15 points
   ring 985 has 99 points
   ring 986 has 45 points
   ring 987 has 89 points
   ring 988 has 9 points
   ring 989 has 12 points
   ring 990 has 20 points
   ring 991 has 22 points
   ring 992 has 23 points
   ring 993 has 17 points
   ring 994 has 9 points
   ring 995 has 8 points
   ring 996 has 21 points
   ring 997 has 201 points
   ring 998 has 8 points
   ring 999 has 15 points
   ring 1000 has 14 points
   ring 1001 has 17 points
   ring 1002 has 9 points
   ring 1003 has 8 points
   ring 1004 has 9 points
   ring 1005 has 51 points
   ring 1006 has 26 points
   ring 1007 has 10 points
   ring 1008 has 10 points
   ring 1009 has 111 points
   ring 1010 has 18 points
   ring 1011 has 12 points
   ring 1012 has 10 points
   ring 1013 has 9 points
   ring 1014 has 13 points
   ring 1015 has 9 points
   ring 1016 has 9 points
   ring 1017 has 12 points
   ring 1018 has 9 points
   ring 1019 has 13 points
   ring 1020 has 11 points
   ring 1021 has 14 points
   ring 1022 has 9 points
   ring 1023 has 13 points
   ring 1024 has 12 points
   ring 1025 has 13 points
   ring 1026 has 11 points
   ring 1027 has 12 points
   ring 1028 has 58 points
   ring 1029 has 13 points
   ring 1030 has 35 points
   ring 1031 has 14 points
   ring 1032 has 17 points
   ring 1033 has 22 points
   ring 1034 has 15 points
   ring 1035 has 18 points
   ring 1036 has 9 points
   ring 1037 has 13 points
   ring 1038 has 14 points
   ring 1039 has 9 points
   ring 1040 has 10 points
   ring 1041 has 96 points
   ring 1042 has 7 points
   ring 1043 has 51 points
   ring 1044 has 10 points
   ring 1045 has 9 points
   ring 1046 has 12 points
   ring 1047 has 9 points
   ring 1048 has 8 points
   ring 1049 has 9 points
   ring 1050 has 10 points
   ring 1051 has 15 points
   ring 1052 has 10 points
   ring 1053 has 14 points
   ring 1054 has 11 points
   ring 1055 has 18 points
   ring 1056 has 23 points
   ring 1057 has 9 points
   ring 1058 has 10 points
   ring 1059 has 8 points
   ring 1060 has 10 points
   ring 1061 has 41 points
   ring 1062 has 10 points
   ring 1063 has 9 points
   ring 1064 has 8 points
   ring 1065 has 32 points
   ring 1066 has 16 points
   ring 1067 has 9 points
   ring 1068 has 62 points
   ring 1069 has 9 points
   ring 1070 has 15 points
   ring 1071 has 11 points
   ring 1072 has 9 points
   ring 1073 has 10 points
   ring 1074 has 7 points
   ring 1075 has 9 points
   ring 1076 has 52 points
   ring 1077 has 14 points
   ring 1078 has 10 points
   ring 1079 has 10 points
   ring 1080 has 11 points
   ring 1081 has 15 points
   ring 1082 has 8 points
   ring 1083 has 19 points
   ring 1084 has 16 points
   ring 1085 has 14 points
   ring 1086 has 12 points
   ring 1087 has 8 points
   ring 1088 has 15 points
   ring 1089 has 10 points
   ring 1090 has 9 points
   ring 1091 has 13 points
   ring 1092 has 17 points
   ring 1093 has 10 points
   ring 1094 has 26 points
   ring 1095 has 9 points
   ring 1096 has 13 points
   ring 1097 has 11 points
   ring 1098 has 10 points
   ring 1099 has 10 points
   ring 1100 has 18 points
   ring 1101 has 17 points
   ring 1102 has 11 points
   ring 1103 has 11 points
   ring 1104 has 9 points
   ring 1105 has 15 points
   ring 1106 has 8 points
   ring 1107 has 73 points
   ring 1108 has 9 points
   ring 1109 has 7 points
   ring 1110 has 11 points
   ring 1111 has 9 points
   ring 1112 has 13 points
   ring 1113 has 10 points
   ring 1114 has 12 points
   ring 1115 has 50 points
   ring 1116 has 15 points
   ring 1117 has 32 points
   ring 1118 has 9 points
   ring 1119 has 9 points
   ring 1120 has 7 points
   ring 1121 has 16 points
   ring 1122 has 14 points
   ring 1123 has 8 points
   ring 1124 has 11 points
   ring 1125 has 9 points
   ring 1126 has 9 points
   ring 1127 has 12 points
   ring 1128 has 14 points
   ring 1129 has 8 points
   ring 1130 has 9 points
   ring 1131 has 9 points
   ring 1132 has 8 points
   ring 1133 has 8 points
   ring 1134 has 11 points
   ring 1135 has 19 points
   ring 1136 has 9 points
   ring 1137 has 9 points
   ring 1138 has 8 points
   ring 1139 has 26 points
   ring 1140 has 9 points
   ring 1141 has 12 points
   ring 1142 has 10 points
   ring 1143 has 12 points
   ring 1144 has 11 points
   ring 1145 has 30 points
   ring 1146 has 10 points
   ring 1147 has 9 points
   ring 1148 has 11 points
   ring 1149 has 15 points
   ring 1150 has 9 points
   ring 1151 has 10 points
   ring 1152 has 10 points
   ring 1153 has 10 points
   ring 1154 has 8 points
   ring 1155 has 11 points
   ring 1156 has 9 points
   ring 1157 has 11 points
   ring 1158 has 15 points
   ring 1159 has 34 points
   ring 1160 has 9 points
   ring 1161 has 10 points
   ring 1162 has 10 points
   ring 1163 has 11 points
   ring 1164 has 13 points
   ring 1165 has 9 points
   ring 1166 has 13 points
   ring 1167 has 15 points
   ring 1168 has 15 points
   ring 1169 has 18 points
   ring 1170 has 56 points
   ring 1171 has 9 points
   ring 1172 has 19 points
   ring 1173 has 8 points
   ring 1174 has 11 points
   ring 1175 has 9 points
   ring 1176 has 9 points
   ring 1177 has 8 points
   ring 1178 has 9 points
   ring 1179 has 52 points
   ring 1180 has 10 points
   ring 1181 has 30 points
   ring 1182 has 19 points
   ring 1183 has 19 points
   ring 1184 has 12 points
   ring 1185 has 10 points
   ring 1186 has 14 points
   ring 1187 has 11 points
   ring 1188 has 7 points
   ring 1189 has 10 points
   ring 1190 has 14 points
   ring 1191 has 12 points
   ring 1192 has 17 points
   ring 1193 has 9 points
   ring 1194 has 9 points
   ring 1195 has 9 points
   ring 1196 has 8 points
   ring 1197 has 11 points
   ring 1198 has 31 points
   ring 1199 has 11 points
   ring 1200 has 10 points
   ring 1201 has 9 points
   ring 1202 has 17 points
   ring 1203 has 11 points
   ring 1204 has 9 points
   ring 1205 has 109 points
   ring 1206 has 14 points
   ring 1207 has 11 points
   ring 1208 has 9 points
   ring 1209 has 9 points
   ring 1210 has 9 points
   ring 1211 has 12 points
   ring 1212 has 20 points
   ring 1213 has 8 points
   ring 1214 has 55 points
   ring 1215 has 9 points
   ring 1216 has 9 points
   ring 1217 has 9 points
   ring 1218 has 16 points
   ring 1219 has 8 points
   ring 1220 has 8 points
   ring 1221 has 10 points
   ring 1222 has 8 points
   ring 1223 has 12 points
   ring 1224 has 10 points
   ring 1225 has 151 points
   ring 1226 has 8 points
   ring 1227 has 19 points
   ring 1228 has 9 points
   ring 1229 has 10 points
   ring 1230 has 41 points
   ring 1231 has 9 points
   ring 1232 has 8 points
   ring 1233 has 10 points
   ring 1234 has 16 points
   ring 1235 has 9 points
   ring 1236 has 9 points
   ring 1237 has 13 points
   ring 1238 has 10 points
   ring 1239 has 66 points
   ring 1240 has 8 points
   ring 1241 has 10 points
   ring 1242 has 10 points
   ring 1243 has 42 points
   ring 1244 has 67 points
   ring 1245 has 15 points
   ring 1246 has 16 points
   ring 1247 has 23 points
   ring 1248 has 9 points
   ring 1249 has 9 points
   ring 1250 has 12 points
   ring 1251 has 75 points
   ring 1252 has 136 points
   ring 1253 has 14 points
   ring 1254 has 28 points
   ring 1255 has 9 points
   ring 1256 has 11 points
   ring 1257 has 9 points
   ring 1258 has 11 points
   ring 1259 has 10 points
   ring 1260 has 460 points
   ring 1261 has 8 points
   ring 1262 has 24 points
   ring 1263 has 9 points
   ring 1264 has 61 points
   ring 1265 has 10 points
   ring 1266 has 10 points
   ring 1267 has 13 points
   ring 1268 has 7 points
   ring 1269 has 18 points
   ring 1270 has 28 points
   ring 1271 has 60 points
   ring 1272 has 36 points
   ring 1273 has 110 points
   ring 1274 has 34 points
   ring 1275 has 49 points
   ring 1276 has 40 points
   ring 1277 has 14 points
   ring 1278 has 21 points
   ring 1279 has 48 points
   ring 1280 has 49 points
   ring 1281 has 9 points
   ring 1282 has 10 points
   ring 1283 has 90 points
   ring 1284 has 13 points
   ring 1285 has 17 points
   ring 1286 has 13 points
   ring 1287 has 20 points
   ring 1288 has 12 points
   ring 1289 has 25 points
   ring 1290 has 8 points
   ring 1291 has 8 points
   ring 1292 has 7 points
   ring 1293 has 7 points
   ring 1294 has 14 points
   ring 1295 has 10 points
   ring 1296 has 9 points
   ring 1297 has 8 points
   ring 1298 has 8 points
   ring 1299 has 26 points
   ring 1300 has 91 points
   ring 1301 has 9 points
   ring 1302 has 60 points
   ring 1303 has 27 points
   ring 1304 has 10 points
   ring 1305 has 9 points
   ring 1306 has 7 points
   ring 1307 has 10 points
   ring 1308 has 7 points
   ring 1309 has 11 points
   ring 1310 has 9 points
   ring 1311 has 59 points
   ring 1312 has 10 points
   ring 1313 has 10 points
   ring 1314 has 9 points
   ring 1315 has 41 points
   ring 1316 has 8 points
   ring 1317 has 49 points
   ring 1318 has 9 points
   ring 1319 has 59 points
   ring 1320 has 47 points
   ring 1321 has 30 points
   ring 1322 has 38 points
   ring 1323 has 24 points
   ring 1324 has 11 points
   ring 1325 has 8 points
   ring 1326 has 42 points
   ring 1327 has 47 points
   ring 1328 has 29 points
   ring 1329 has 62 points
   ring 1330 has 97 points
   ring 1331 has 8 points
   ring 1332 has 9 points
   ring 1333 has 8 points
   ring 1334 has 9 points
   ring 1335 has 38 points
   ring 1336 has 15 points
   ring 1337 has 69 points
   ring 1338 has 9 points
   ring 1339 has 9 points
   ring 1340 has 12 points
   ring 1341 has 10 points
   ring 1342 has 8 points
   ring 1343 has 8 points
   ring 1344 has 11 points
   ring 1345 has 10 points
   ring 1346 has 6 points
   ring 1347 has 8 points
   ring 1348 has 15 points
   ring 1349 has 8 points
   ring 1350 has 10 points
   ring 1351 has 9 points
   ring 1352 has 206 points
   ring 1353 has 9 points
   ring 1354 has 12 points
   ring 1355 has 8 points
   ring 1356 has 43 points
   ring 1357 has 10 points
   ring 1358 has 9 points
   ring 1359 has 11 points
   ring 1360 has 10 points
   ring 1361 has 11 points
   ring 1362 has 161 points
   ring 1363 has 18 points
   ring 1364 has 8 points
   ring 1365 has 8 points
   ring 1366 has 10 points
   ring 1367 has 67 points
   ring 1368 has 8 points
   ring 1369 has 13 points
   ring 1370 has 12 points
   ring 1371 has 23 points
   ring 1372 has 12 points
   ring 1373 has 35 points
   ring 1374 has 35 points
   ring 1375 has 7 points
   ring 1376 has 8 points
   ring 1377 has 15 points
   ring 1378 has 9 points
   ring 1379 has 8 points
   ring 1380 has 9 points
   ring 1381 has 9 points
   ring 1382 has 26 points
   ring 1383 has 8 points
   ring 1384 has 9 points
   ring 1385 has 21 points
   ring 1386 has 24 points
   ring 1387 has 16 points
   ring 1388 has 23 points
   ring 1389 has 8 points
   ring 1390 has 13 points
   ring 1391 has 7 points
   ring 1392 has 236 points
   ring 1393 has 9 points
   ring 1394 has 9 points
   ring 1395 has 9 points
   ring 1396 has 8 points
   ring 1397 has 17 points
   ring 1398 has 8 points
   ring 1399 has 6 points
   ring 1400 has 10 points
   ring 1401 has 9 points
   ring 1402 has 9 points
   ring 1403 has 14 points
   ring 1404 has 9 points
   ring 1405 has 7 points
   ring 1406 has 9 points
   ring 1407 has 9 points
   ring 1408 has 8 points
   ring 1409 has 11 points
   ring 1410 has 9 points
   ring 1411 has 21 points
   ring 1412 has 9 points
   ring 1413 has 8 points
   ring 1414 has 8 points
   ring 1415 has 8 points
   ring 1416 has 8 points
   ring 1417 has 11 points
   ring 1418 has 14 points
   ring 1419 has 8 points
   ring 1420 has 8 points
   ring 1421 has 9 points
   ring 1422 has 7 points
   ring 1423 has 7 points
   ring 1424 has 172 points
   ring 1425 has 8 points
   ring 1426 has 37 points
   ring 1427 has 11 points
   ring 1428 has 84 points
   ring 1429 has 9 points
   ring 1430 has 132 points
   ring 1431 has 9 points
   ring 1432 has 114 points
   ring 1433 has 174 points
   ring 1434 has 88 points
   ring 1435 has 10 points
   ring 1436 has 49 points
   ring 1437 has 9 points
   ring 1438 has 17 points
   ring 1439 has 9 points
   ring 1440 has 332 points
   ring 1441 has 11 points
   ring 1442 has 78 points
   ring 1443 has 14 points
   ring 1444 has 8 points
   ring 1445 has 56 points
   ring 1446 has 8 points
   ring 1447 has 9 points
   ring 1448 has 10 points
   ring 1449 has 9 points
   ring 1450 has 6 points
   ring 1451 has 9 points
   ring 1452 has 10 points
   ring 1453 has 9 points
   ring 1454 has 12 points
   ring 1455 has 10 points
   ring 1456 has 11 points
   ring 1457 has 10 points
   ring 1458 has 26 points
   ring 1459 has 8 points
   ring 1460 has 33 points
   ring 1461 has 80 points
   ring 1462 has 11 points
   ring 1463 has 29 points
   ring 1464 has 11 points
   ring 1465 has 7 points
   ring 1466 has 33 points
   ring 1467 has 8 points
   ring 1468 has 7 points
   ring 1469 has 12 points
   ring 1470 has 10 points
   ring 1471 has 145 points
   ring 1472 has 10 points
   ring 1473 has 23 points
   ring 1474 has 12 points
   ring 1475 has 8 points
   ring 1476 has 132 points
   ring 1477 has 12 points
   ring 1478 has 8 points
   ring 1479 has 16 points
   ring 1480 has 7 points
   ring 1481 has 10 points
   ring 1482 has 9 points
   ring 1483 has 7 points
   ring 1484 has 10 points
   ring 1485 has 14 points
   ring 1486 has 10 points
   ring 1487 has 11 points
   ring 1488 has 330 points
   ring 1489 has 16 points
   ring 1490 has 9 points
   ring 1491 has 11 points
   ring 1492 has 20 points
   ring 1493 has 12 points
   ring 1494 has 8 points
   ring 1495 has 12 points
   ring 1496 has 10 points
   ring 1497 has 23 points
   ring 1498 has 8 points
   ring 1499 has 17 points
   ring 1500 has 15 points
   ring 1501 has 13 points
   ring 1502 has 9 points
   ring 1503 has 47 points
   ring 1504 has 14 points
   ring 1505 has 28 points
   ring 1506 has 10 points
   ring 1507 has 525 points
   ring 1508 has 12 points
   ring 1509 has 9 points
   ring 1510 has 11 points
   ring 1511 has 9 points
   ring 1512 has 9 points
   ring 1513 has 8 points
   ring 1514 has 11 points
   ring 1515 has 8 points
   ring 1516 has 10 points
   ring 1517 has 9 points
   ring 1518 has 9 points
   ring 1519 has 9 points
   ring 1520 has 12 points
   ring 1521 has 9 points
   ring 1522 has 85 points
   ring 1523 has 8 points
   ring 1524 has 10 points
   ring 1525 has 10 points
   ring 1526 has 9 points
   ring 1527 has 8 points
   ring 1528 has 12 points
   ring 1529 has 20 points
   ring 1530 has 8 points
   ring 1531 has 9 points
   ring 1532 has 38 points
   ring 1533 has 31 points
   ring 1534 has 9 points
   ring 1535 has 8 points
   ring 1536 has 10 points
   ring 1537 has 50 points
   ring 1538 has 9 points
   ring 1539 has 232 points
   ring 1540 has 13 points
   ring 1541 has 17 points
   ring 1542 has 82 points
   ring 1543 has 16 points
   ring 1544 has 12 points
   ring 1545 has 9 points
   ring 1546 has 8 points
   ring 1547 has 19 points
   ring 1548 has 10 points
   ring 1549 has 32 points
   ring 1550 has 9 points
   ring 1551 has 8 points
   ring 1552 has 9 points
   ring 1553 has 8 points
   ring 1554 has 8 points
   ring 1555 has 8 points
   ring 1556 has 9 points
   ring 1557 has 9 points
   ring 1558 has 9 points
   ring 1559 has 12 points
   ring 1560 has 9 points
   ring 1561 has 10 points
   ring 1562 has 13 points
   ring 1563 has 10 points
   ring 1564 has 34 points
   ring 1565 has 8 points
   ring 1566 has 10 points
   ring 1567 has 9 points
   ring 1568 has 61 points
   ring 1569 has 12 points
   ring 1570 has 8 points
   ring 1571 has 16 points
   ring 1572 has 9 points
   ring 1573 has 9 points
   ring 1574 has 159 points
   ring 1575 has 12 points
   ring 1576 has 7 points
   ring 1577 has 8 points
   ring 1578 has 8 points
   ring 1579 has 8 points
   ring 1580 has 9 points
   ring 1581 has 8 points
   ring 1582 has 8 points
   ring 1583 has 10 points
   ring 1584 has 7 points
   ring 1585 has 10 points
   ring 1586 has 10 points
   ring 1587 has 13 points
   ring 1588 has 9 points
   ring 1589 has 12 points
   ring 1590 has 9 points
   ring 1591 has 10 points
   ring 1592 has 9 points
   ring 1593 has 7 points
   ring 1594 has 17 points
   ring 1595 has 8 points
   ring 1596 has 12 points
   ring 1597 has 9 points
   ring 1598 has 10 points
   ring 1599 has 12 points
   ring 1600 has 48 points
   ring 1601 has 20 points
   ring 1602 has 8 points
   ring 1603 has 20 points
   ring 1604 has 7 points
   ring 1605 has 9 points
   ring 1606 has 7 points
   ring 1607 has 8 points
   ring 1608 has 8 points
   ring 1609 has 7 points
   ring 1610 has 9 points
   ring 1611 has 8 points
   ring 1612 has 8 points
   ring 1613 has 87 points
   ring 1614 has 8 points
   ring 1615 has 9 points
   ring 1616 has 10 points
   ring 1617 has 20 points
   ring 1618 has 8 points
   ring 1619 has 7 points
   ring 1620 has 9 points
   ring 1621 has 8 points
   ring 1622 has 10 points
   ring 1623 has 10 points
   ring 1624 has 8 points
   ring 1625 has 8 points
   ring 1626 has 40 points
   ring 1627 has 9 points
   ring 1628 has 20 points
   ring 1629 has 9 points
   ring 1630 has 7 points
   ring 1631 has 9 points
   ring 1632 has 8 points
   ring 1633 has 63 points
   ring 1634 has 7 points
   ring 1635 has 8 points
   ring 1636 has 45 points
   ring 1637 has 9 points
   ring 1638 has 11 points
   ring 1639 has 12 points
   ring 1640 has 13 points
   ring 1641 has 7 points
   ring 1642 has 49 points
   ring 1643 has 9 points
   ring 1644 has 9 points
   ring 1645 has 12 points
   ring 1646 has 15 points
   ring 1647 has 8 points
   ring 1648 has 10 points
   ring 1649 has 9 points
   ring 1650 has 11 points
   ring 1651 has 9 points
   ring 1652 has 9 points
   ring 1653 has 9 points
   ring 1654 has 12 points
   ring 1655 has 16 points
   ring 1656 has 7 points
   ring 1657 has 10 points
   ring 1658 has 8 points
   ring 1659 has 10 points
   ring 1660 has 8 points
   ring 1661 has 8 points
   ring 1662 has 9 points
   ring 1663 has 9 points
   ring 1664 has 21 points
   ring 1665 has 9 points
   ring 1666 has 13 points
   ring 1667 has 25 points
   ring 1668 has 39 points
   ring 1669 has 36 points
   ring 1670 has 9 points
   ring 1671 has 10 points
   ring 1672 has 27 points
   ring 1673 has 11 points
   ring 1674 has 11 points
   ring 1675 has 8 points
   ring 1676 has 12 points
   ring 1677 has 9 points
   ring 1678 has 26 points
   ring 1679 has 11 points
   ring 1680 has 9 points
   ring 1681 has 164 points
   ring 1682 has 8 points
   ring 1683 has 9 points
   ring 1684 has 35 points
   ring 1685 has 8 points
   ring 1686 has 11 points
   ring 1687 has 9 points
   ring 1688 has 11 points
   ring 1689 has 10 points
   ring 1690 has 13 points
   ring 1691 has 10 points
   ring 1692 has 7 points
   ring 1693 has 13 points
   ring 1694 has 20 points
   ring 1695 has 14 points
   ring 1696 has 117 points
   ring 1697 has 26 points
   ring 1698 has 13 points
   ring 1699 has 46 points
   ring 1700 has 9 points
   ring 1701 has 27 points
   ring 1702 has 106 points
   ring 1703 has 22 points
   ring 1704 has 58 points
   ring 1705 has 9 points
   ring 1706 has 8 points
   ring 1707 has 9 points
   ring 1708 has 14 points
   ring 1709 has 9 points
   ring 1710 has 8 points
   ring 1711 has 15 points
   ring 1712 has 109 points
   ring 1713 has 12 points
   ring 1714 has 11 points
   ring 1715 has 19 points
   ring 1716 has 55 points
   ring 1717 has 15 points
   ring 1718 has 11 points
   ring 1719 has 7 points
   ring 1720 has 8 points
   ring 1721 has 34 points
   ring 1722 has 15 points
   ring 1723 has 12 points
   ring 1724 has 9 points
   ring 1725 has 30 points
   ring 1726 has 32 points
   ring 1727 has 9 points
   ring 1728 has 8 points
   ring 1729 has 9 points
   ring 1730 has 7 points
   ring 1731 has 9 points
   ring 1732 has 15 points
   ring 1733 has 18 points
   ring 1734 has 9 points
   ring 1735 has 17 points
   ring 1736 has 13 points
   ring 1737 has 17 points
   ring 1738 has 7 points
   ring 1739 has 8 points
   ring 1740 has 14 points
   ring 1741 has 32 points
   ring 1742 has 8 points
   ring 1743 has 8 points
   ring 1744 has 8 points
   ring 1745 has 10 points
   ring 1746 has 9 points
   ring 1747 has 9 points
   ring 1748 has 9 points
   ring 1749 has 8 points
   ring 1750 has 8 points
   ring 1751 has 9 points
   ring 1752 has 9 points
   ring 1753 has 8 points
   ring 1754 has 8 points
   ring 1755 has 72 points
   ring 1756 has 8 points
   ring 1757 has 7 points
   ring 1758 has 9 points
   ring 1759 has 9 points
   ring 1760 has 8 points
   ring 1761 has 10 points
   ring 1762 has 9 points
   ring 1763 has 9 points
   ring 1764 has 7 points
   ring 1765 has 71 points
   ring 1766 has 14 points
   ring 1767 has 9 points
   ring 1768 has 39 points
   ring 1769 has 31 points
   ring 1770 has 9 points
   ring 1771 has 10 points
   ring 1772 has 10 points
   ring 1773 has 9 points
   ring 1774 has 9 points
   ring 1775 has 11 points
   ring 1776 has 12 points
   ring 1777 has 8 points
   ring 1778 has 18 points
   ring 1779 has 7 points
   ring 1780 has 9 points
   ring 1781 has 10 points
   ring 1782 has 8 points
   ring 1783 has 9 points
   ring 1784 has 9 points
   ring 1785 has 499 points
   ring 1786 has 8 points
   ring 1787 has 14 points
   ring 1788 has 7 points
   ring 1789 has 8 points
   ring 1790 has 9 points
   ring 1791 has 10 points
   ring 1792 has 10 points
   ring 1793 has 9 points
   ring 1794 has 6 points
   ring 1795 has 10 points
   ring 1796 has 7 points
   ring 1797 has 9 points
   ring 1798 has 8 points
   ring 1799 has 11 points
   ring 1800 has 8 points
   ring 1801 has 24 points
   ring 1802 has 10 points
   ring 1803 has 11 points
   ring 1804 has 14 points
   ring 1805 has 8 points
   ring 1806 has 10 points
   ring 1807 has 9 points
   ring 1808 has 23 points
   ring 1809 has 16 points
   ring 1810 has 14 points
   ring 1811 has 81 points
   ring 1812 has 27 points
   ring 1813 has 7 points
   ring 1814 has 11 points
   ring 1815 has 8 points
   ring 1816 has 7 points
   ring 1817 has 9 points
   ring 1818 has 16 points
   ring 1819 has 8 points
   ring 1820 has 9 points
   ring 1821 has 13 points
   ring 1822 has 8 points
   ring 1823 has 9 points
   ring 1824 has 8 points
   ring 1825 has 10 points
   ring 1826 has 10 points
   ring 1827 has 36 points
   ring 1828 has 9 points
   ring 1829 has 70 points
   ring 1830 has 8 points
   ring 1831 has 8 points
   ring 1832 has 66 points
   ring 1833 has 10 points
   ring 1834 has 9 points
   ring 1835 has 11 points
   ring 1836 has 9 points
   ring 1837 has 24 points
   ring 1838 has 32 points
   ring 1839 has 10 points
   ring 1840 has 8 points
   ring 1841 has 18 points
   ring 1842 has 8 points
   ring 1843 has 9 points
   ring 1844 has 7 points
   ring 1845 has 9 points
   ring 1846 has 29 points
   ring 1847 has 8 points
   ring 1848 has 13 points
   ring 1849 has 10 points
   ring 1850 has 17 points
   ring 1851 has 10 points
   ring 1852 has 9 points
   ring 1853 has 13 points
   ring 1854 has 8 points
   ring 1855 has 9 points
   ring 1856 has 11 points
   ring 1857 has 16 points
   ring 1858 has 9 points
   ring 1859 has 16 points
   ring 1860 has 27 points
   ring 1861 has 12 points
   ring 1862 has 8 points
   ring 1863 has 54 points
   ring 1864 has 35 points
   ring 1865 has 8 points
   ring 1866 has 23 points
   ring 1867 has 50 points
   ring 1868 has 8 points
   ring 1869 has 10 points
   ring 1870 has 9 points
   ring 1871 has 9 points
   ring 1872 has 8 points
   ring 1873 has 17 points
   ring 1874 has 9 points
   ring 1875 has 12 points
   ring 1876 has 7 points
   ring 1877 has 9 points
   ring 1878 has 9 points
   ring 1879 has 10 points
   ring 1880 has 9 points
   ring 1881 has 16 points
   ring 1882 has 13 points
   ring 1883 has 7 points
   ring 1884 has 10 points
   ring 1885 has 19 points
   ring 1886 has 8 points
   ring 1887 has 15 points
   ring 1888 has 9 points
   ring 1889 has 22 points
   ring 1890 has 9 points
   ring 1891 has 10 points
   ring 1892 has 9 points
   ring 1893 has 10 points
   ring 1894 has 8 points
   ring 1895 has 8 points
   ring 1896 has 26 points
   ring 1897 has 10 points
   ring 1898 has 7 points
   ring 1899 has 10 points
   ring 1900 has 8 points
   ring 1901 has 71 points
   ring 1902 has 9 points
   ring 1903 has 11 points
   ring 1904 has 11 points
   ring 1905 has 9 points
   ring 1906 has 24 points
   ring 1907 has 12 points
   ring 1908 has 15 points
   ring 1909 has 26 points
   ring 1910 has 7 points
   ring 1911 has 31 points
   ring 1912 has 15 points
   ring 1913 has 15 points
   ring 1914 has 11 points
   ring 1915 has 118 points
   ring 1916 has 11 points
   ring 1917 has 11 points
   ring 1918 has 27 points
   ring 1919 has 101 points
   ring 1920 has 78 points
   ring 1921 has 10 points
   ring 1922 has 7 points
   ring 1923 has 6 points
   ring 1924 has 45 points
   ring 1925 has 7 points
   ring 1926 has 7 points
   ring 1927 has 7 points
   ring 1928 has 7 points
   ring 1929 has 7 points
   ring 1930 has 6 points
   ring 1931 has 9 points
   ring 1932 has 10 points
   ring 1933 has 15 points
   ring 1934 has 10 points
   ring 1935 has 20 points
   ring 1936 has 9 points
   ring 1937 has 10 points
   ring 1938 has 10 points
   ring 1939 has 17 points
   ring 1940 has 23 points
   ring 1941 has 63 points
   ring 1942 has 14 points
   ring 1943 has 9 points
   ring 1944 has 18 points
   ring 1945 has 8 points
   ring 1946 has 16 points
   ring 1947 has 9 points
   ring 1948 has 64 points
   ring 1949 has 213 points
   ring 1950 has 8 points
   ring 1951 has 9 points
   ring 1952 has 61 points
   ring 1953 has 9 points
   ring 1954 has 11 points
   ring 1955 has 27 points
   ring 1956 has 27 points
   ring 1957 has 29 points
   ring 1958 has 10 points
   ring 1959 has 8 points
   ring 1960 has 8 points
   ring 1961 has 9 points
   ring 1962 has 9 points
   ring 1963 has 8 points
   ring 1964 has 9 points
   ring 1965 has 7 points
   ring 1966 has 10 points
   ring 1967 has 8 points
   ring 1968 has 12 points
   ring 1969 has 8 points
   ring 1970 has 16 points
   ring 1971 has 8 points
   ring 1972 has 8 points
   ring 1973 has 14 points
   ring 1974 has 9 points
   ring 1975 has 15 points
   ring 1976 has 8 points
   ring 1977 has 8 points
   ring 1978 has 11 points
   ring 1979 has 9 points
   ring 1980 has 10 points
   ring 1981 has 10 points
   ring 1982 has 11 points
   ring 1983 has 12 points
   ring 1984 has 9 points
   ring 1985 has 167 points
   ring 1986 has 16 points
   ring 1987 has 19 points
   ring 1988 has 56 points
   ring 1989 has 19 points
   ring 1990 has 11 points
   ring 1991 has 19 points
   ring 1992 has 36 points
   ring 1993 has 32 points
   ring 1994 has 297 points
   ring 1995 has 153 points
   ring 1996 has 43 points
   ring 1997 has 9 points
   ring 1998 has 15 points
   ring 1999 has 9 points
   ring 2000 has 19 points
   ring 2001 has 8 points
   ring 2002 has 9 points
   ring 2003 has 7 points
   ring 2004 has 8 points
   ring 2005 has 20 points
   ring 2006 has 8 points
   ring 2007 has 7 points
   ring 2008 has 11 points
   ring 2009 has 16 points
   ring 2010 has 13 points
   ring 2011 has 9 points
   ring 2012 has 26 points
   ring 2013 has 13 points
   ring 2014 has 19 points
   ring 2015 has 9 points
   ring 2016 has 32 points
   ring 2017 has 10 points
   ring 2018 has 8 points
   ring 2019 has 9 points
   ring 2020 has 9 points
   ring 2021 has 10 points
   ring 2022 has 9 points
   ring 2023 has 10 points
   ring 2024 has 9 points
   ring 2025 has 8 points
   ring 2026 has 8 points
   ring 2027 has 10 points
   ring 2028 has 9 points
   ring 2029 has 8 points
   ring 2030 has 8 points
   ring 2031 has 9 points
   ring 2032 has 10 points
   ring 2033 has 9 points
   ring 2034 has 10 points
   ring 2035 has 14 points
   ring 2036 has 11 points
   ring 2037 has 10 points
   ring 2038 has 33 points
   ring 2039 has 8 points
   ring 2040 has 12 points
   ring 2041 has 9 points
   ring 2042 has 9 points
   ring 2043 has 8 points
   ring 2044 has 19 points
   ring 2045 has 8 points
   ring 2046 has 10 points
   ring 2047 has 18 points
   ring 2048 has 9 points
   ring 2049 has 30 points
   ring 2050 has 10 points
   ring 2051 has 8 points
   ring 2052 has 10 points
   ring 2053 has 8 points
   ring 2054 has 38 points
   ring 2055 has 9 points
   ring 2056 has 11 points
   ring 2057 has 11 points
   ring 2058 has 8 points
   ring 2059 has 7 points
   ring 2060 has 8 points
   ring 2061 has 7 points
   ring 2062 has 8 points
   ring 2063 has 11 points
   ring 2064 has 9 points
   ring 2065 has 9 points
   ring 2066 has 40 points
   ring 2067 has 9 points
   ring 2068 has 8 points
   ring 2069 has 10 points
   ring 2070 has 9 points
   ring 2071 has 12 points
   ring 2072 has 11 points
   ring 2073 has 9 points
   ring 2074 has 8 points
   ring 2075 has 8 points
   ring 2076 has 9 points
   ring 2077 has 9 points
   ring 2078 has 10 points
   ring 2079 has 19 points
   ring 2080 has 9 points
   ring 2081 has 8 points
   ring 2082 has 10 points
   ring 2083 has 9 points
   ring 2084 has 7 points
   ring 2085 has 8 points
   ring 2086 has 9 points
   ring 2087 has 8 points
   ring 2088 has 128 points
   ring 2089 has 12 points
   ring 2090 has 9 points
   ring 2091 has 9 points
   ring 2092 has 8 points
   ring 2093 has 9 points
   ring 2094 has 8 points
   ring 2095 has 8 points
   ring 2096 has 8 points
   ring 2097 has 9 points
   ring 2098 has 17 points
   ring 2099 has 34 points
   ring 2100 has 16 points
   ring 2101 has 11 points
   ring 2102 has 11 points
   ring 2103 has 10 points
   ring 2104 has 10 points
   ring 2105 has 12 points
   ring 2106 has 9 points
   ring 2107 has 77 points
   ring 2108 has 15 points
   ring 2109 has 8 points
   ring 2110 has 9 points
   ring 2111 has 8 points
   ring 2112 has 11 points
   ring 2113 has 8 points
   ring 2114 has 9 points
   ring 2115 has 10 points
   ring 2116 has 8 points
   ring 2117 has 99 points
   ring 2118 has 9 points
   ring 2119 has 12 points
   ring 2120 has 11 points
   ring 2121 has 22 points
   ring 2122 has 63 points
   ring 2123 has 18 points
   ring 2124 has 61 points
   ring 2125 has 20 points
   ring 2126 has 596 points
   ring 2127 has 11 points
   ring 2128 has 73 points
   ring 2129 has 10 points
   ring 2130 has 22 points
   ring 2131 has 149 points
   ring 2132 has 195 points
   ring 2133 has 21 points
   ring 2134 has 11 points
   ring 2135 has 10 points
   ring 2136 has 8 points
   ring 2137 has 41 points
   ring 2138 has 7 points
   ring 2139 has 11 points
   ring 2140 has 10 points
   ring 2141 has 15 points
   ring 2142 has 10 points
   ring 2143 has 13 points
   ring 2144 has 8 points
   ring 2145 has 8 points
   ring 2146 has 8 points
   ring 2147 has 9 points
   ring 2148 has 8 points
   ring 2149 has 10 points
   ring 2150 has 8 points
   ring 2151 has 9 points
   ring 2152 has 7 points
   ring 2153 has 9 points
   ring 2154 has 10 points
   ring 2155 has 10 points
   ring 2156 has 8 points
   ring 2157 has 12 points
   ring 2158 has 9 points
   ring 2159 has 8 points
   ring 2160 has 8 points
   ring 2161 has 12 points
   ring 2162 has 9 points
   ring 2163 has 10 points
   ring 2164 has 9 points
   ring 2165 has 8 points
   ring 2166 has 8 points
   ring 2167 has 8 points
   ring 2168 has 7 points
   ring 2169 has 12 points
   ring 2170 has 8 points
   ring 2171 has 17 points
   ring 2172 has 9 points
   ring 2173 has 10 points
   ring 2174 has 13 points
   ring 2175 has 8 points
   ring 2176 has 41 points
   ring 2177 has 28 points
   ring 2178 has 9 points
   ring 2179 has 11 points
   ring 2180 has 17 points
   ring 2181 has 37 points
   ring 2182 has 8 points
   ring 2183 has 9 points
   ring 2184 has 8 points
   ring 2185 has 9 points
   ring 2186 has 8 points
   ring 2187 has 9 points
   ring 2188 has 26 points
   ring 2189 has 11 points
   ring 2190 has 10 points
   ring 2191 has 9 points
   ring 2192 has 20 points
   ring 2193 has 10 points
   ring 2194 has 13 points
   ring 2195 has 14 points
   ring 2196 has 12 points
   ring 2197 has 20 points
   ring 2198 has 13 points
   ring 2199 has 9 points
   ring 2200 has 39 points
   ring 2201 has 8 points
   ring 2202 has 34 points
   ring 2203 has 13 points
   ring 2204 has 15 points
   ring 2205 has 9 points
   ring 2206 has 9 points
   ring 2207 has 13 points
   ring 2208 has 9 points
   ring 2209 has 9 points
   ring 2210 has 8 points
   ring 2211 has 28 points
   ring 2212 has 11 points
   ring 2213 has 7 points
   ring 2214 has 53 points
   ring 2215 has 8 points
   ring 2216 has 11 points
   ring 2217 has 14 points
   ring 2218 has 10 points
   ring 2219 has 8 points
   ring 2220 has 11 points
   ring 2221 has 18 points
   ring 2222 has 27 points
   ring 2223 has 11 points
   ring 2224 has 9 points
   ring 2225 has 11 points
   ring 2226 has 10 points
   ring 2227 has 8 points
   ring 2228 has 30 points
   ring 2229 has 28 points
   ring 2230 has 10 points
   ring 2231 has 10 points
   ring 2232 has 14 points
   ring 2233 has 11 points
   ring 2234 has 10 points
   ring 2235 has 9 points
   ring 2236 has 21 points
   ring 2237 has 9 points
   ring 2238 has 8 points
   ring 2239 has 9 points
   ring 2240 has 12 points
   ring 2241 has 9 points
   ring 2242 has 11 points
   ring 2243 has 13 points
   ring 2244 has 10 points
   ring 2245 has 10 points
   ring 2246 has 12 points
   ring 2247 has 12 points
   ring 2248 has 10 points
   ring 2249 has 12 points
   ring 2250 has 10 points
   ring 2251 has 13 points
   ring 2252 has 8 points
   ring 2253 has 31 points
   ring 2254 has 8 points
   ring 2255 has 20 points
   ring 2256 has 19 points
   ring 2257 has 9 points
   ring 2258 has 74 points
   ring 2259 has 9 points
   ring 2260 has 10 points
   ring 2261 has 18 points
   ring 2262 has 9 points
   ring 2263 has 10 points
   ring 2264 has 7 points
   ring 2265 has 9 points
   ring 2266 has 13 points
   ring 2267 has 8 points
   ring 2268 has 12 points
   ring 2269 has 12 points
   ring 2270 has 9 points
   ring 2271 has 8 points
   ring 2272 has 23 points
   ring 2273 has 18 points
   ring 2274 has 7 points
   ring 2275 has 21 points
   ring 2276 has 9 points
   ring 2277 has 10 points
   ring 2278 has 8 points
   ring 2279 has 8 points
   ring 2280 has 26 points
   ring 2281 has 19 points
   ring 2282 has 8 points
   ring 2283 has 11 points
   ring 2284 has 8 points
   ring 2285 has 9 points
   ring 2286 has 9 points
   ring 2287 has 9 points
   ring 2288 has 15 points
   ring 2289 has 11 points
   ring 2290 has 11 points
   ring 2291 has 14 points
   ring 2292 has 9 points
   ring 2293 has 9 points
   ring 2294 has 12 points
   ring 2295 has 7 points
   ring 2296 has 10 points
   ring 2297 has 28 points
   ring 2298 has 8 points
   ring 2299 has 8 points
   ring 2300 has 9 points
   ring 2301 has 14 points
   ring 2302 has 15 points
   ring 2303 has 9 points
   ring 2304 has 17 points
   ring 2305 has 13 points
   ring 2306 has 8 points
   ring 2307 has 15 points
   ring 2308 has 12 points
   ring 2309 has 12 points
   ring 2310 has 7 points
   ring 2311 has 12 points
   ring 2312 has 9 points
   ring 2313 has 20 points
   ring 2314 has 33 points
   ring 2315 has 10 points
   ring 2316 has 16 points
   ring 2317 has 8 points
   ring 2318 has 9 points
   ring 2319 has 7 points
   ring 2320 has 141 points
   ring 2321 has 8 points
   ring 2322 has 9 points
   ring 2323 has 8 points
   ring 2324 has 17 points
   ring 2325 has 8 points
   ring 2326 has 8 points
   ring 2327 has 9 points
   ring 2328 has 8 points
   ring 2329 has 9 points
   ring 2330 has 14 points
   ring 2331 has 18 points
   ring 2332 has 10 points
   ring 2333 has 7 points
   ring 2334 has 9 points
   ring 2335 has 12 points
   ring 2336 has 16 points
   ring 2337 has 8 points
   ring 2338 has 9 points
   ring 2339 has 8 points
   ring 2340 has 9 points
   ring 2341 has 9 points
   ring 2342 has 14 points
   ring 2343 has 8 points
   ring 2344 has 9 points
   ring 2345 has 9 points
   ring 2346 has 9 points
   ring 2347 has 9 points
   ring 2348 has 10 points
   ring 2349 has 11 points
   ring 2350 has 9 points
   ring 2351 has 126 points
   ring 2352 has 7 points
   ring 2353 has 14 points
   ring 2354 has 9 points
   ring 2355 has 9 points
   ring 2356 has 13 points
   ring 2357 has 8 points
   ring 2358 has 10 points
   ring 2359 has 7 points
   ring 2360 has 8 points
   ring 2361 has 13 points
   ring 2362 has 9 points
   ring 2363 has 8 points
   ring 2364 has 11 points
   ring 2365 has 9 points
   ring 2366 has 10 points
   ring 2367 has 9 points
   ring 2368 has 9 points
   ring 2369 has 9 points
   ring 2370 has 10 points
   ring 2371 has 12 points
   ring 2372 has 12 points
   ring 2373 has 12 points
   ring 2374 has 15 points
   ring 2375 has 9 points
   ring 2376 has 9 points
   ring 2377 has 14 points
   ring 2378 has 9 points
   ring 2379 has 9 points
   ring 2380 has 8 points
   ring 2381 has 8 points
   ring 2382 has 19 points
   ring 2383 has 9 points
   ring 2384 has 8 points
   ring 2385 has 9 points
   ring 2386 has 9 points
   ring 2387 has 34 points
   ring 2388 has 9 points
   ring 2389 has 16 points
   ring 2390 has 12 points
   ring 2391 has 9 points
   ring 2392 has 9 points
   ring 2393 has 8 points
   ring 2394 has 14 points
   ring 2395 has 9 points
   ring 2396 has 11 points
   ring 2397 has 9 points
   ring 2398 has 20 points
   ring 2399 has 11 points
   ring 2400 has 13 points
   ring 2401 has 14 points
   ring 2402 has 9 points
   ring 2403 has 9 points
   ring 2404 has 9 points
   ring 2405 has 9 points
   ring 2406 has 9 points
   ring 2407 has 11 points
   ring 2408 has 11 points
   ring 2409 has 31 points
   ring 2410 has 9 points
   ring 2411 has 10 points
   ring 2412 has 9 points
   ring 2413 has 8 points
   ring 2414 has 10 points
   ring 2415 has 12 points
   ring 2416 has 73 points
   ring 2417 has 13 points
   ring 2418 has 10 points
   ring 2419 has 26 points
   ring 2420 has 12 points
   ring 2421 has 10 points
   ring 2422 has 7 points
   ring 2423 has 9 points
   ring 2424 has 9 points
   ring 2425 has 9 points
   ring 2426 has 9 points
   ring 2427 has 10 points
   ring 2428 has 9 points
   ring 2429 has 9 points
   ring 2430 has 9 points
   ring 2431 has 10 points
   ring 2432 has 7 points
   ring 2433 has 9 points
   ring 2434 has 39 points
   ring 2435 has 8 points
   ring 2436 has 12 points
   ring 2437 has 9 points
   ring 2438 has 9 points
   ring 2439 has 11 points
   ring 2440 has 11 points
   ring 2441 has 9 points
   ring 2442 has 8 points
   ring 2443 has 10 points
   ring 2444 has 10 points
   ring 2445 has 7 points
   ring 2446 has 9 points
   ring 2447 has 10 points
   ring 2448 has 9 points
   ring 2449 has 7 points
   ring 2450 has 12 points
   ring 2451 has 13 points
   ring 2452 has 16 points
   ring 2453 has 17 points
   ring 2454 has 9 points
   ring 2455 has 9 points
   ring 2456 has 12 points
   ring 2457 has 20 points
   ring 2458 has 9 points
   ring 2459 has 18 points
   ring 2460 has 9 points
   ring 2461 has 8 points
   ring 2462 has 9 points
   ring 2463 has 10 points
   ring 2464 has 11 points
   ring 2465 has 8 points
   ring 2466 has 9 points
   ring 2467 has 9 points
   ring 2468 has 15 points
   ring 2469 has 9 points
   ring 2470 has 9 points
   ring 2471 has 11 points
   ring 2472 has 8 points
   ring 2473 has 10 points
   ring 2474 has 9 points
   ring 2475 has 9 points
   ring 2476 has 11 points
   ring 2477 has 12 points
   ring 2478 has 13 points
   ring 2479 has 8 points
   ring 2480 has 10 points
   ring 2481 has 20 points
   ring 2482 has 10 points
   ring 2483 has 10 points
   ring 2484 has 10 points
   ring 2485 has 10 points
   ring 2486 has 9 points
   ring 2487 has 9 points
   ring 2488 has 10 points
   ring 2489 has 8 points
   ring 2490 has 8 points
   ring 2491 has 21 points
   ring 2492 has 12 points
   ring 2493 has 25 points
   ring 2494 has 10 points
   ring 2495 has 9 points
   ring 2496 has 8 points
   ring 2497 has 12 points
   ring 2498 has 9 points
   ring 2499 has 8 points
   ring 2500 has 9 points
   ring 2501 has 10 points
   ring 2502 has 9 points
   ring 2503 has 8 points
   ring 2504 has 10 points
   ring 2505 has 11 points
   ring 2506 has 12 points
(1 row)
