[postgis-users] Instllation problem on WinXP
Akio Takubo takubo at saruga-tondara.net
Tue Oct 31 09:23:33 PST 2006
Hello Mark,
On Tue, 31 Oct 2006 11:07:30 +0000
Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk> wrote:
> On Fri, 2006-10-27 at 03:06 +0900, Akio Takubo wrote:
> > Hello all,
> > I have a strange problem with PostGIS installer for Win32.
> > Have anyone experienced these problem?
> > In my case ...
> > I failed install into only WinXP SP2 *Japanese* edition,
> > when I tryed PostGIS installer with some environments.
> > Some user also said that they have same problem with WInXP SP2 (Japanese).
> > This is a list of my test environments and its result. All env are Win32 not Win64.
> > * WinXP Pro SP2 (Japanese) failed
> > * WinXP Pro SP1 (Japanese) success
> > * WinXP Pro SP2 (English) success
> > * Win2003 Server SP1 (Japanese) success
> > I got same above result by all these installers.
> > * pgInstaller(PostgreSQL 8.1.4) + PostGIS installer (1.1.3)
> > * pgInstaller(PostgreSQL 8.1.5) + PostGIS installer (1.1.5)
> > * pgInstaller(PostgreSQL 8.2beta2 with PostGIS 1.1.5)
> > So there is no problem on SP1 or English ver or Win2003server.
> > But at least I can sucess install WinXP SP2 (Japanese) following combination.
> > * pgInstaller(PostgreSQL 8.1.4 + PostGIS 1.0.5 or PostGIS1.0.6)
> > * pgInstaller(PostgreSQL 8.1.4) + PostGIS 1.1.3 (I built with Linux/Mingw32 envrironment)
> > This error occured a runtime of lwpostgis.sql.
> > One example error message is:
> >    psql:../share/contrib/lwpostgis.sql;;35 ERROR:  could not load library
> >    "C:/Program Files/PostgreSQL/8.1/lib/liblwgeom.dll": ( Error message in japanese)
> > It seems that LoadLibrary API fails to load liblwgeom.dll with 998 (ERROR_NOACCESS) error.
> > I thought that there is some compatibility issue (C++ memory managemnet related?)
> > with WinXP SP2 japanese and current PostGIS build envirnment.
> > Can anyone solve this?
> > Best regards,
> >    Akio Takubo @ OSGeo-Japan
> Hi Akio,
> The only reason I can think of as to why liblwgeom.dll would fail to
> load under SP2 is that Windows cannot find a dependent DLL. The setup
> used to build the installer is WinXP SP2 English, and as you correctly
> note, the installer works fine under this setup.
> A useful starting point would be to run the Microsoft Dependency Checker
> (depends.exe) and FileMon (filemon.exe) on your SP1 and SP2 installs to
> determine if there are any dependency differences between the two
> versions of Windows - both of these utilities can be found using Google.
> Posting any differences back to the list should help give a better
> picture as to why PostgreSQL is failing to load the DLL.
> Kind regards,
> Mark.
> postgis-users mailing list
Ok, I know both tools you said. I can try these for both Japanese SP2 and
other environment tomorrow. If these shows diffrent result,
I'll report its deail of result to list.
Thanks for your advice!
Best regards,
