[postgis-users] Multi-ring polygons not imported properly.
Michael Fuhr mike at fuhr.org
Mon Sep 18 19:38:19 PDT 2006
On Mon, Sep 18, 2006 at 10:42:35AM -0400, Kjel Anderson wrote:
> I am having an interesting problem. I am importing a shapefile of u.s.
> counties. When I import the shapefile, the first row that has a multi-ring
> polygon, only imports the first ring. Subsequent rows with multiple rings
> come through fine. I am using the shp2pgsql tool. Anyone have any ideas about
> what I might try on this?
How do you know that the geometry that was imported with a single
ring really has multiple rings?  Is the shapefile publicly available
or can you make it available for testing?  If so then please post
a link and indicate which row you're having trouble with.
Michael Fuhr
