[postgis-users] Shp2pgsql problem 2
Stefan Hahmann s.hahmann at mapchart.com
Wed Apr 18 03:06:06 PDT 2007
Hi frank, david
Thank you for your help with the shapefile import. Switching off the
32-bit option and changing the way the shp2pgsql | psql commands were
invoked did help.
But now another problem occured:
After i have successfully loaded data into my table _g24 using
shp2pgsql -s 4326 -c -I -D -k myshapefile1.shp public._g24 | psql -d
mapdata
I was not able to append data using
shp2pgsql -s 4326 -c -I -D -k myshapefile2.shp public._g24 | psql -d
mapdata
Although myshapefile1.shp and myshapefile2 do have the same structure.
I got again an errormessage:
ERROR:  syntax error at or near "2760003221743" at character 1
LINE 1: 2760003221743 4110 0 100000000005583 0 522760200562014 0 0 1...
My table structure is:
CREATE TABLE _g24
  gid serial NOT NULL,
  "ID" bigint,
Maybe somebody can help?
Thanks in advance.
