[postgis-users] transform problem
Peter Bange bange at argoss.nl
Mon Apr 23 00:29:44 PDT 2007
Hi Mark,
Thanks for your advice, I'll try it later on.
regards, Peter
On Apr 18, 2007, at 13:59, Mark Cave-Ayland wrote:
> On Tue, 2007-04-17 at 11:09 +0200, Peter Bange wrote:
>> Hi Mark,
>> I tried some other transformation, but no succes; the simplest a
>> tried
>> was:
>> TestDB=# select transform(geomfromtext('Point(4.4 52.0)', 3395),
>> 4001);
>> server closed the connection unexpectedly
>>         This probably means the server terminated abnormally
>>         before or while processing the request.
>> The connection to the server was lost. Attempting reset: Failed.
>> Any idea ?
>> Peter
> Hmmm. Can you provide the output of 'SELECT version()' and 'SELECT
> postgis_full_version()' just in case it only appears with particular
> builds. Also, is it possible to recompile with -g and attach gdb to
> the
> backend in order to get a backtrace when the crash occurs?
> Kind regards,
> Mark.
> postgis-users mailing list
ARGOSS: your partner for atmospheric, marine & coastal information
P O Box 61
8325ZH Vollenhove The Netherlands
tel +31-527-242299 fax +31-527-242016
Web http://www.argoss.nl
Confidentiality Notice & Disclaimer
The contents of this e-mail and any attachments are intended only for
the
use of the e-mail addressee(s) shown. If you are not that person, or
one of
those persons, you are not allowed to take any action based upon it
or to
copy it, forward, distribute or disclose the contents of it and you
should
please delete it from your system.
ARGOSS Holding BV and its subsidiaries do not accept any liability
for any
errors or omissions in the context of this e-mail or its attachments
which
arise as a result of Internet transmission, nor accept liability for
statements which are those of the author and not clearly made on
behalf of
ARGOSS.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070423/9e2ee591/attachment.html>
