[postgis-users] TopologyException: side location conflict
Martin Davis mbdavis at refractions.net
Mon Apr 23 09:34:21 PDT 2007
Can you post two geometries which cause the error?
Both WKT and WKB would be nice.
Stefan Zweig wrote:
> hi @ all,
> i have following problem with the postgis WITHIN method:
> i am trying to check whether some polygons from one layer/table are within a polygon from another layer/table and i am doing this with this sql command:
> SELECT p."POSTCODE"
> FROM _countys b AS b, postcodes AS p
> WHERE b."NAME"='florida' AND p."the_geom" @ b."the_geom" = true
> AND WITHIN(p."the_geom", b."the_geom") = true
> this works fine but takes i while to be procedured. so i wanted to make the within check faster by simplifying the source geometries (EPSG: 4326):
> SELECT p."POSTCODE"
> AND WITHIN(simplify(p."the_geom",0.001), simplify(b."the_geom",0.001)) = true
> but then i get the following error:
> NOTICE:  TopologyException: side location conflict (-81.0351,26.6027,26.6027)
> ERROR: GEOS within() threw an error!
> SQL Status:XX000
> i am wondering why the within operator does not work with simplified coordinates / geometries.
> btw.: i does not seem that this error occurs with any within/simplify usage, only in some cases.
> i appreciate any help.
> stefan
> _______________________________________________________________
> SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
> kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
