[postgis-users] How to improve the performance in GIS functions
Jose Gomez-Dans jgomezdans at gmail.com
Thu Aug 9 01:55:13 PDT 2007
Hi Andreas,
On 8/9/07, Andreas Laggner <bloediandi at web.de> wrote:
> I have to improve the performance from PostGis: LK Gifhorn takes 19
> seconds in ArcGis and 6 Minutes with PostGis. The intersection InVeKos
> with Atkis all over lower saxony (niedersachsen) runs since 14 hours
> now!!! That is overkill. Does someone know how to make PostGis faster in
> GIS functions?
You should really specify more clearly what you are trying to do, and
what sort of data you're using. As a first step, creating and using
spatial indices  should give you a noticeable speed improvement. Start
here: <http://postgis.refractions.net/docs/ch03.html#id2684759>.
Good luck!
