[postgis-users] dblink experiences? multiple geom copies in multiple databases
John Smith jayzee.smith at gmail.com
Mon Aug 13 11:59:00 PDT 2007
interesting.
i also see a postgis template database. does that only help to
spatially enable new databases (likely) or also help spatial queries
from other databases (not likely, but if so, how is this
inter-database querying happening)?
jzs
On 8/13/07, Paul Ramsey <pramsey at refractions.net> wrote:
> Correct, that's how most do it. dblink is an option, but I have no
> experience to share on that. Just from a straight design PoV though,
> the complete opacity of a dblink table in terms of size, selectivity,
> indexes, etc, means that you'll have to be pretty careful about what
> use cases you try and push through that pipe -- it's not a
> transparent gateway, it's more of a straw.
> P
> On 13-Aug-07, at 7:02 AM, John Smith wrote:
> > given this:
> > - cluster
> > -- database
> > --- schema (except public schema can be accessed from outside)
> > ---- table, function etc
> > it means (and i didn't want to accept this conclusion) most postgis
> > shops have 1 kick-ass database for all their geom and related non-geom
> > tables separated by named schemas. users, permissions etc are all
> > restricted by these named schemas and *all* geom tables are contained
> > in this monster database (to avoid duplication).
> > well that'll certainly ease administration :).
> > On 8/11/07, Paul Ramsey <pramsey at refractions.net> wrote:
> >> In what respect do you find that postgis doesn't support multiple
> >> schemas?  We generally install postgis in 'public.' and create lots
> > http://postgis.refractions.net/pipermail/postgis-users/2006-January/
> > 010602.html
> > jzs
> >> On 10-Aug-07, at 2:05 PM, John Smith wrote:
> >>> postgresql doesn't support queries across multiple databases and
> >>> postgis doesn't support multiple schemas, so how'd you guys do it?\\
> >> of other schemas ('foo.', 'water.', 'etc.') for our data tables.
> >> P
