RE: [postgis-users] An I/O error occured while sending to the backend
Stefan Zweig stefanzweig1881 at web.de
Wed Aug 15 06:45:33 PDT 2007
hi mark, hi list,
i have a problem with running these querys:
 SELECT
 AddGeometryColumn('public','_g2994','the_geom_1','4326','MULTIPOLYGON',2);
 ALTER TABLE _g2994 DROP CONSTRAINT enforce_geotype_the_geom_1;
 ALTER TABLE _g2994 ADD CONSTRAINT enforce_geotype_the_geom_1 CHECK
 (geometrytype(the_geom_1) = 'MULTIPOLYGON'::text OR geometrytype(the_geom_1)
 = 'POLYGON'::text OR the_geom_1 IS NULL);
 everthing is alright up to here...
 then i run
 UPDATE _g2994 SET the_geom_1 = buffer(simplify(the_geom,0.0063775005),0)
 WHERE true
unfortunately i am not an expert in reading postgres' server.log but this what happens after the above querys where executed:
LOG:  server process (PID 10410) was terminated by signal 11
LOG:  terminating any other active server processes
WARNING:  terminating connection because of crash of another server process
DETAIL:  The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
HINT:  In a moment you should be able to reconnect to the database and repeat your command.
LOG:  all server processes terminated; reinitializing
LOG:  database system was interrupted at 2007-08-15 15:35:56 CEST
LOG:  checkpoint record is at 2F/26448BC4
LOG:  redo record is at 2F/26448BC4; undo record is at 0/0; shutdown FALSE
LOG:  next transaction ID: 88945157; next OID: 2557087
LOG:  next MultiXactId: 1; next MultiXactOffset: 0
LOG:  database system was not properly shut down; automatic recovery in progress
LOG:  redo starts at 2F/26448C08
LOG:  unexpected pageaddr 2F/1E45A000 in log file 47, segment 38, offset 4562944
LOG:  redo done at 2F/26459A80
LOG:  database system is ready
LOG:  transaction ID wrap limit is 2147484146, limited by database "postgres"
> -----Ursprüngliche Nachricht-----
> Von: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Gesendet: 14.08.07 09:42:00
> An: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Betreff: RE: [postgis-users] An I/O error occured while sending to the backend
> On Tue, 2007-08-14 at 09:25 +0200, Stefan Zweig wrote:
> > i am wondering why postgre has to restart after i run that update query. that actually should not be, should it?
> > regards, stefan
> Hi Stefan,
> If PostgreSQL is restarting, you will find more information in the
> server log. Posting the relevant section of the log to the list would
> probably help diagnose the problem.
> Kind regards,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-users mailing list
_____________________________________________________________________
Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
http://smartsurfer.web.de/?mc=100071&distributionid=000000000066
