[postgis-users] monthly climate query
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Wed Aug 15 12:08:31 PDT 2007
avgpar, FROM weather
eliminate the comma.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
Web-Based Water Supply Planning Demo:
http://soulswimmer.dynalias.net/models/wsdemo/demo_hsi.php
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kirk
Wythers
Sent: Wednesday, August 15, 2007 2:58 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] monthly climate query
You were right Regina. I did some testing and the subselects were indeed
returning averages for the entire weather table.
I also pulled all the -999 values out and replaced them with NULLs. The
way it should have been in the first place.
Here is my latest crack at your suggestions (including getting rid of
the double subselect), However I'm getting syntax error at the FROM
weather line at the end that I just can't find. Do you see it?
SELECT CASE
WHEN w.station_id = site_near.station_id THEN w.obs_id
            ELSE s.obs_id
            END AS obs_id, site_near.station_id, site_near.longname,
w.year, w.doy
FROM   site_near
INNER JOIN solar s
            ON (site_near.ref_solar_station_id = s.station_id AND
site_near.obs_year = s.year)
INNER JOIN weather w
            ON (site_near.ref_weather_station_id = w.station_id AND
site_near.obs_year = w.year AND s.date = w.date)
INNER JOIN (SELECT   month, station_id,
            round(avg(precip)::numeric, 2) AS avgprecip,
            round(avg(tmin)::numeric, 2) AS avgtmin,
            round(avg(tmax)::numeric, 2) AS avgtmax,
            round(avg(par)::numeric, 2) AS avgpar,
FROM weather
GROUP BY month, station_id) AS avgclim
WHERE  w.station_id = 219101;
On Aug 14, 2007, at 3:44 PM, Obe, Regina wrote:
Yes I think you did or I missed something.  Your subselects are going to
return the average for the whole weather and solar tables (not for just
that reference site) which doesn't quite seem like what you want if you
are trying to put realistic placeholders for missing data in a site.
Also I don't think you need to do 2 subselects for weather - I think you
can combine into a single one with something like below
(SELECT   MONTH, station_id,
                            round(avg(CASE WHEN precip != -999 THEN
precip ELSE NULL END)::numeric, 2) AS avgprecip,
                         round(avg(CASE WHEN tmax != -999 THEN tmax ELSE
NULL END)::numeric, 2) AS avgtmax,
                   FROM     weather
                   GROUP BY MONTH, station_id) As wmonthsummer
Actually if you had put in NULLS for precip amd tmax instead of -999,
you would be better off since those fall out of the equation quite
nicely since aggregates completely ignore null.
And then you could blissfully do
                   FROM     weather
Hope that helps,
Regina
  _____
Wythers
Sent: Tuesday, August 14, 2007 4:25 PM
If I follow your point Regina (as far as the working daily query goes),
I am returning data for a particular site based on the last line...
WHERE w.station_id = some_valid_number.
Did I miss something?
On Aug 14, 2007, at 3:13 PM, Obe, Regina wrote:
Wouldn't you want to return the average for month for that particular
site?  None of your month subselects seem to group by station id.  Would
seem to me logically you should add station_id to each of your
subselects, group by station_id as well as month and then your ON clause
would be month and station_id.
Hope that helps,
Regina
  _____
Wythers
Sent: Tuesday, August 14, 2007 12:15 PM
To: Discussion PostGIS Users
Subject: [postgis-users] monthly climate query
I need some help with rewriting a query. I have a query that dumps daily
climate data, filling in missing data with monthly averages (one line
per day).
I want to output monthly averages (one line per month). I am having a
hard time wrapping my head around this. Particularly how to deal with
the doy column (day of year). I have tried several approaches and my
forehead is starting to get my keyboard bloody.
Here is the daily query:
SELECT CASE
ELSE s.obs_id
END AS obs_id,
site_near.longname,
w.year,
w.doy,
--replace missing values (-999) with the monthly average
       CASE w.tmax
         WHEN -999 THEN avgtmax.avg
         ELSE w.tmax
       END,
CASE w.tmin
         WHEN -999 THEN avgtmin.avg
         ELSE w.tmin
       END,
CASE s.par
         WHEN -999 THEN avgpar.avg
         ELSE s.par
       END,
CASE w.precip
         WHEN -999 THEN avgprecip.avg
         ELSE w.precip
       END
FROM  site_near
       INNER JOIN solar s
             AND site_near.obs_year = s.year)
             AND site_near.obs_year = w.year
       INNER JOIN (SELECT   MONTH,
                   FROM     weather
                   WHERE    tmax != -999
                   GROUP BY MONTH) AS avgtmax
         ON (w.month = avgtmax.month)
                   FROM     weather
                   WHERE    tmin != -999
                   GROUP BY MONTH) AS avgtmin
         ON (w.month = avgtmin.month)
                   FROM     solar
                   WHERE    par != -999
                   GROUP BY MONTH) AS avgpar
         ON (s.month = avgpar.month)
                   FROM     weather
                   WHERE    precip != -999
                   GROUP BY MONTH) AS avgprecip
         ON (w.month = avgprecip.month)
--select station to output climate data by id number
  _____
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure pursuant
to Massachusetts law. It is intended solely for the addressee. If you
received this in error, please contact the sender and delete the
material from any computer.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
  _____
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070815/25000798/attachment.html>
