[postgis-users] Mac OS X installation problem - no "coveredby" in liblwgeom.1.3.so"
Webb Sprague webb.sprague at gmail.com
Sat Aug 18 19:52:38 PDT 2007
On 8/18/07, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I'm looking at this now, for updating my OSX PostGIS distribution.  I
> was able to successfully upgrade an older postgis DB with
> lwpostgis_upgrade.sql - it adds the _ST_CoveredBy function exactly
> like lwpostgis.sql.  No errors finding the coveredby function.
When date you download and do all this?
Thx!
W
> I also build with the --with-pgsql flag, so postgis is installed
> inside the postgres dir.
> On Aug 18, 2007, at 11:01 AM, Webb Sprague wrote:
> >> I must confess I've never used the --with-libdir arguments to
> >> configure
> >> - I've always gone for explicit --with-pgsql, --with-geos, and
> >> --with-proj switches. If you check
> >> the /usr/local/postgis-1.3.1/share/lwpostgis.sql, does it contain the
> >> correct path to liblwgeom.1.3.so?
> > Hi,
> > Yes, lwpostgis.sql contains the correct path - in fact, the previous
> > line of SQL  works just fine and finds liblwgeom for other functions.
> > It is only this line and subsequent that fails.
> > I intsalled geos right before building installing postgis.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
