[postgis-users] Calculating bbox/extent for set of polygons: ERROR I don't understand
Matthew Pettis matthew.pettis at gmail.com
Sun Aug 19 20:55:02 PDT 2007
I'm trying to calculate a minimum bbox/extent for a group of polygons with a
similar attribute.  For this specific case, I am trying to find a
bbox/extent for all of the voting precincts within the same county.
here is the sql I'm executing:
select
distinct
    extent(the_geom) as the_extent
from
    shp_precincts
where
    county_id = 72
'the_geom' is a polygon representing a voting precinct, and the where clause
subsets to all voting precincts belonging to a specific county.  I get the
following error which I don't understand or know how to correct:
ERROR:  could not identify an ordering operator for type box2d
HINT:  Use an explicit ordering operator or modify the query.
Any help is appreciated in resolving this.  What I ultimately want to do is
have a result set that has a bounding box for each county based on the
polygons of precincts that belong to that county.
tia,
Matt
It is from the wellspring of our despair and the places that we are broken
that we come to repair the world.
-- Murray Waas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070819/e82f5dac/attachment.html>
