[postgis-users] Problem with st_endpoint in postgis 1.3.1 for windows
Francois Eric ericfrancois at hotmail.com
Tue Aug 21 14:41:50 PDT 2007
Hello,
I have a problem when I run st_endpoint function : the query kill the process.
The same query with st_startpoint works fine. I'm also able to run st_endpoint with postgis 1.2.1 with no problem.
My conf
Windows XP
"PostgreSQL 8.2.4 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.2 (mingw-special)"
"POSTGIS="1.3.1" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS"
The log
2007-08-21 23:11:04 STATEMENT: select y(st _endpoint(the_geom)) from streets limit 10
2007-08-21 23:11:16 LOG: server process (PID 4988) exited with exit code -1073741819
2007-08-21 23:11:16 LOG: terminating any other active server processes
2007-08-21 23:11:16 WARNING: terminating connection because of crash of another server process
2007-08-21 23:11:16 DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2007-08-21 23:11:16 HINT: In a moment you should be able to reconnect to the database and repeat your command.
2007-08-21 23:11:16 LOG: all server processes terminated; reinitializing
2007-08-21 23:11:16 LOG: database system was interrupted at 2007-08-21 23:09:07 Paris, Madrid
2007-08-21 23:11:16 LOG: checkpoint record is at 5/D3ECC1D0
2007-08-21 23:11:16 LOG: redo record is at 5/D3ECC1D0; undo record is at 0/0; shutdown FALSE
2007-08-21 23:11:16 LOG: next transaction ID: 0/1226346; next OID: 101454
2007-08-21 23:11:16 LOG: next MultiXactId: 1; next MultiXactOffset: 0
2007-08-21 23:11:16 LOG: database system was not properly shut down; automatic recovery in progress
2007-08-21 23:11:16 LOG: redo starts at 5/D3ECC220
2007-08-21 23:11:16 LOG: record with zero length at 5/D42FAF58
2007-08-21 23:11:16 LOG: redo done at 5/D42FAF28
2007-08-21 23:11:18 LOG: database system is ready
Thanks for your help
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070821/60159da9/attachment.html>
