[postgis-users] postgres 8.1 postgis 1.3.1 upgrade issues on win32
Stephen Woodbridge woodbri at swoodbridge.com
Sat Aug 25 09:08:34 PDT 2007
I'm trying to upgrade postGIS on my WinXP laptop. The installer is
aborting with the following error:
  Output folder: C:\DOCUME~1\woodbri\LOCALS~1\Temp\postgis_installer
  UserName=postgres
  Password=****
  Port=5432
  Checking for existing PostGIS installation...
  ERROR: Could not open file
C:\DOCUME~1\woodbri\LOCALS~1\Temp\postgis_installer\check_templatepostgis_output.txt
The batch file used for this test is:
set PGPASSWORD=****
  set PGPORT=5432
  "C:\Program Files\PostgreSQL\8.1\bin\psql.exe" -U postgres -h
localhost -l -t -c "SELECT 'true' FROM pg_database WHERE
datname='template_postgis'" -d template1 >
"C:\DOCUME~1\woodbri\LOCALS~1\Temp\postgis_installer\check_templatepostgis_output.txt"
2>
"C:\DOCUME~1\woodbri\LOCALS~1\Temp\postgis_installer\check_templatepostgis_error.txt"
the SELECT above returns zero rows. I tried adding a database
"template_postgis" but that did not help resolve the issue?
"POSTGIS="1.1.3" GEOS="2.2.2-CAPI-1.1.0" PROJ="Rel. 4.4.9, 29 Oct 2004"
USE_STATS"
"PostgreSQL 8.1.4 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
3.4.2 (mingw-special)"
Any thoughts on working around this issue?
Thanks,
   -Steve
