[postgis-users] Geometry Functions?
Leonardo Mateo leonardomateo at gmail.com
Mon Aug 27 14:28:17 PDT 2007
On 8/27/07, chris hinkle <lilhinx at gmail.com> wrote:
> I think the problem is simpler than that, select postgis_full_version();
> gives the same error.
> Is there a step I'm missing to initialize the db with the functions?
You have to execute lwpostgis.sql and spatial_ref_sys.sql files on the
database you want to be GIS database.
These files are distributed with PostGIS, I don't know where are they on
windows distribution but read the docs or search your hard drive to find
them.
That's what I meant when I asked you if you turned the database into a GIS
database.
Hope it helps.
Leonardo Mateo.
There's no place like ~
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070827/d85e7003/attachment.html>
