[postgis-users] Moving PostGIS tables between different PGSQL+PostGIS versions
Jose Gomez-Dans jgomezdans at gmail.com
Thu Aug 30 05:32:30 PDT 2007
On 8/30/07, Leonardo Mateo <leonardomateo at gmail.com> wrote:
> On 8/30/07, Jose Gomez-Dans <jgomezdans at gmail.com> wrote:
> > I have a number of tables in PostGIS (1.1.6, PGSQL 8.1). I want to
> > move them to another server (which is running PostGIS 1.3.1 and 8.2).
> > Apart from dumping the databases (pg_dump), do I need to take other
> > things into account? The tables are fairly simple, and at most have
> > PostGIS extensions or are plain tables.
> Which platform R U working on? I've done this on a Linux and is fairly
> simple but you will need a little of bash scripting but if you're
> working on Windows I can't help you
I'm on LInux, so any pointers will be much appreciated :)
Cheers!
Jose
