[postgis-users] Error installing on Linux Centos 5
Kevin Neufeld kneufeld at refractions.net
Sat Dec 1 10:24:47 PST 2007
If you want to install postgresql and postgis to the latest, don't yum
install them ... download and install them both from source.
1) download and install postgresql
http://www.postgresql.org/docs/8.2/static/install-short.html
2) download and install the latest geos
http://geos.refractions.net/
3) download and install proj.4
http://www.remotesensing.org/proj/
4) change to contrib directory in your source tree of postgresql and
install postgis
http://postgis.refractions.net/docs/ch02.html
You may have to specify the location of pg_config location with
--with-pgsql when installing postgis (perhaps as well as the --with-geos
and --with-proj options as well).
Cheers,
Kevin
Andre Schoonbee wrote:
> Hi All
> Hope this is not a blond moment, But I cannot get postgis 1.2.1
> installed on my Centos 5. Postgresql is running and I can connect to
> the database. I have downloaded the tar.gz file and extracted it. When
> running./configure all goes well until I get and error that PostgreSQL
> is needed.
> Any help will be appreciated.
> I also wan to upgrade both  postgresql and postgis to the latest, but
> yum is not detecting the latest versions. I downloaded the tar.gz
> files but this does not upgrade the previous PostgreSQL version when
> installing it.
> Please help
> Andre
> postgis-users mailing list
