[postgis-users] shp2pgsql problems on Mac OS X Leopard
Patrick Hartling patrick.hartling at priority5.com
Wed Dec 5 08:32:07 PST 2007
I have run into a rather perplexing problem with shp2pgsql from
PostGIS 1.3.1 and 1.3.2 on Mac OS X Leopard. As far as I can tell, the
optarg and optind variables declared in ParseCmdline() of loader/
shp2pgsql.c are being linked to the globals declared in unistd.h
rather than those in loader/getopt.h. The result is that references to
these variables in ParseCmdline() give the wrong values. Specifically,
optarg is always NULL, and optind is 0 until the loop in lines 1363
through 1377.
Looking at the output from the preprocessor, optarg, optind, opterr,
and optopt are all  declared twice. The first is from unistd.h, and
the second is from PostGIS' loader/getopt.h. If I remove the #include
directive for unistd.h, shp2pgsql compiles, links, and runs correctly,
although there is a compiler warning saying that getopt() is not
declared.
My guess is that there is some compiler or linker option that might
fix this behavior, but I have not been able to determine what that
might be. Removing the inclusion of unistd.h does not seem like the
best fix, but it is a workaround that gets things running for me.
  -Patrick
Patrick L. Hartling
Senior Software Engineer, Priority 5
http://www.priority5.com/
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071205/f62d612c/attachment.pgp>
