[postgis-users] intersection/within queries - newbie basic spatial queries
Josh Livni josh at umbrellaconsulting.com
Thu Dec 6 22:35:00 PST 2007
Ah - that's probably what he meant - in which case I guessed wrong both
times :)
Since you mentioned the GiST index (and it may well be of use -- perhaps
he's got millions of sec_catch polygons), I just figured I'd point out
to Craigie that if indeed he does have such an index, to take advantage
of it he'd need to add the spatial && operator to the where clause, eg:
  AND b.the_geom && a.the_geom
  -Josh
Kevin Neufeld wrote:
> You're after a list of tuples from sec_catch where the geometry falls
> within some polygon from prim_catch?
> Try to rework your query to something like this.
> SELECT b.secondary
> FROM prim_catch a, sec_catch b
> WHERE ST_Within(b.the_geom, a.the_geom);
> With only 19 geometries in your prim_catch table it's not a big deal,
> but in general, you want to ensure you have a GIST index on both of
> your geometry columns.
> Cheers,
> Kevin
> Craigie Dirk wrote:
>> I am a new user and trying to perform some basic spatial queries
>> using within/intersect/union etc.
>> I have 2 x polygon files :
>> Prim_catch (19 x records)
>> Sec_catch (attribute secondary = text field name of catchment)
>> All the polys in sec_catch fall within a single record (polygon) of
>> prim_catch
>> The query I am using (see below) needs some kind of loop or temporary
>> table as it returns a true/false and not a list of the records = true.
>> SELECT secondary FROM sec_catch
>> WHERE WITHIN((select the_geom from sec_catch),(select the_geom from
>> prim_catch))
>> Any help, sample will be appreciated
>> Thanks,
>> Dirk Craigie
>> DISCLAIMER:
>> This message and any attachments are confidential and intended solely
>> for the addressee. If you have received this message in error, please
>> notify the system manager/sender. Any unauthorized use, alteration or
>> dissemination is prohibited. The Department of Water Affairs and
>> Forestry further accepts no liability whatsoever for any loss,
>> whether it be direct, indirect or consequential, arising from this
>> e-mail, nor for any consequence of its use or storage.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
