[postgis-users] intersection/within queries - newbie basicspatial queries
Josh Livni josh at umbrellaconsulting.com
Fri Dec 7 16:20:10 PST 2007
Kevin,
Thanks for the followup - I guess I knew the ST_ functions wrapped the
spatial queries and wasn't thinking straight - however I never did the
actual tests to see that I've probably been slowing myself down where
keep my old habits and include the && in there.  Interesting.  Thanks!
  -Josh
Kevin Neufeld wrote:
> Correct.  This JOIN query is the same thing that I posted yesterday,
> but using a WHERE clause instead.
> Josh,
> A quick note on your comment about gist indexes.  I totally agree with
> you that you need the && operator, but now in postgis, most of the
> st_* methods are simple wrappers of previous methods and include the
> && operator.
> i.e.
> test=# \df+ st_within
>                                                            List of
> functions
> Schema |   Name    | Result data type | Argument data types |  Owner
> | Language |              Source code              | Description
> public | st_within | boolean          | geometry, geometry  | postgres
> | sql      | SELECT $1 && $2 AND _ST_Within($1,$2) |
> (1 row)
> In fact, I've noticed that sometimes adding an extra && operator can
> make a query take longer.  Here is an example two tiny tables I have:
> test=# explain analyze
> select a.* from neighbourhood_poly a, cityarea_poly b
> where st_within(a.the_Geom, b.the_Geom);
>                                                        QUERY
> PLAN
> Nested Loop  (cost=1.03..4.24 rows=19 width=30271) (actual
> time=2.391..121.782 rows=15 loops=1)
>   Join Filter: ((a.the_geom && b.the_geom) AND _st_within(a.the_geom,
> b.the_geom))
>   ->  Seq Scan on neighbourhood_poly a  (cost=0.00..1.26 rows=26
> width=30271) (actual time=0.049..0.233 rows=26 loops=1)
>   ->  Materialize  (cost=1.03..1.06 rows=3 width=15506) (actual
> time=0.006..0.192 rows=3 loops=26)
>         ->  Seq Scan on cityarea_poly b  (cost=0.00..1.03 rows=3
> width=15506) (actual time=0.015..0.028 rows=3 loops=1)
> Total runtime: 122.979 ms
> (6 rows)
> and b.the_geom && a.the_geom;
>                                                        QUERY
> PLAN
> Nested Loop  (cost=1.03..4.44 rows=14 width=30271) (actual
> time=4.176..190.813 rows=15 loops=1)
> b.the_geom) AND (b.the_geom && a.the_geom))
> width=30271) (actual time=0.048..0.658 rows=26 loops=1)
> time=0.012..0.110 rows=3 loops=26)
> width=15506) (actual time=0.125..0.140 rows=3 loops=1)
> Total runtime: 191.687 ms
> (6 rows)
> This looks like it's due to the fact that the && operator is not
> truely symmetric and the query planner does not disregard the extra
> index lookup.
> Cheers,
> Kevin
> Obe, Regina wrote:
>> You are missing an ON. You can fix by moving your where into the ON
>> SELECT sec_catch.secondary FROM sec_catch INNER JOIN prim_catch ON
>> st_within(sec_catch.the_geom,
>> prim_catch.the_geom)
>> I tend to spell out the type of JOIN too because I can never remember
>> what is the default join behavior in PostgreSQL.
>> Hope that helps,
>> Regina
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Craigie Dirk
>> Sent: Friday, December 07, 2007 1:42 AM
>> To: postgis-users at postgis.refractions.net
>> Cc: dylan
>> Subject: RE: [postgis-users] intersection/within queries - newbie
>> Thanks,
>> 1st case worked perfectly - thanks.
>> 2nd case (more what I am after) gave a syntax error at or near
>> "where" Any ideas on the error ?
>> select sec_catch.secondary from sec_catch join prim_catch
>> where st_within(sec_catch.the_geom, prim_catch.the_geom)
>> Regards,
>> Dirk Craigie
>> From: dylan [mailto:debeaudette at ucdavis.edu] Sent: 07 December 2007
>> 08:27 AM
>> Cc: Craigie Dirk
>> Subject: Re: [postgis-users] intersection/within queries - newbie basic
>> spatial queries
>> On Thursday 06 December 2007 10:02:57 pm Craigie Dirk wrote:
>>> I am a new user and trying to perform some basic spatial queries using
>>> within/intersect/union etc.
>>> I have 2 x polygon files :
>>> Prim_catch (19 x records)
>>> Sec_catch (attribute secondary = text field name of catchment)
>>> All the polys in sec_catch fall within a single record (polygon) of
>>> prim_catch
>>> The query I am using (see below) needs some kind of loop or temporary
>>> table as it returns a true/false and not a list of the records = true.
>>> SELECT secondary FROM sec_catch
>>> WHERE WITHIN((select the_geom from sec_catch),(select the_geom from
>>> prim_catch))
>> Using a join can save typing:
>> select st_intersection(a.geom, b.geom) from a join b on
>> st_intersects(a.geom, b.geom) ;
>> if you want the cartesian product (all possible permutations leave off
>> the ON clause).
>> or if you just want matching records:
>> select a.id from a join b where st_within(a.geom, b,geom);
>> does that help ?
>> Dylan
>> DISCLAIMER:
>> This message and any attachments are confidential and intended solely
>> for the addressee. If you have received this message in error, please
>> notify the system manager/sender.  Any unauthorized use, alteration or
>> dissemination is prohibited.  The Department of Water Affairs and
>> Forestry further accepts no liability whatsoever for any loss, whether
>> it be direct, indirect or consequential, arising from this e-mail, nor
>> for any consequence of its use or storage.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
