[postgis-users] Export empty geometries with pgsql2shp
Matt Doughty matt.doughty at geograma.com
Mon Dec 10 01:35:54 PST 2007
Hi all,
I'm trying to export a series of tables using the pgsql2shp command. The
'problem' I have is that tables that are empty do not export how I want
them to- an empty dbf without column names is exported. What I'm looking
for is to be able to be able to export the tables as shapefiles even if
they have no records (in some case they'll have records, in others no),
which would effectively give me three 'empty' files (shp, shx and dbf),
the dbf however would have the column names.
An ideas to get around this problem?
Cheers,
Matt
Matt Doughty
GEOGRAMA S.L.
Tel.:  +34 945 13 13 72    652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071210/661f45c1/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071210/661f45c1/attachment.jpg>
