[postgis-users] Problem installing PostGIS
Alex Turner armtuk at gmail.com
Mon Dec 10 12:16:54 PST 2007
Is /usr/lib/pgsql/liblwgeom.so.1.3 generated by PostGIS or from the
Postgresql RPMs?  Do I just need to update my postgres version?
Alex
On Dec 10, 2007 12:50 PM, Paul Ramsey <pramsey at refractions.net> wrote:
> There appears to be a mismatch between the .sql file you are using
> and the .so file it's linking to. Check their dates.  All else fails,
> just delete the coveredby definition from the .sql file if you're in
> a hurry.
> P
> On 10-Dec-07, at 9:40 AM, Alex Turner wrote:
> > I am installing PostGIS 1.3.1 from source on RedHat EL5 on
> > Postgresql-8.2.5-2PGDG.rhel5 RPM version
> > I get an error when upping lwpostgis.sql into my test database:
> > CREATE FUNCTION
> > CREATE FUNCTION
> > CREATE FUNCTION
> > psql:/usr/share/lwpostgis.sql:4093: ERROR:  could not find function
> > "coveredby" in file "/usr/lib/pgsql/liblwgeom.so.1.3"
> > psql:/usr/share/lwpostgis.sql:4099: ERROR:  current transaction is
> > aborted, commands ignored until end of transaction block
> > psql:/usr/share/lwpostgis.sql:4105: ERROR:  current transaction is
> > Any insight on this would be greatly appreciated
> > Alex
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071210/6dfc1b6b/attachment.html>
