SV: [postgis-users] Change projection in select?
Runesson Magnus Magnus.Runesson at smhi.se
Thu Dec 13 05:45:01 PST 2007
Thanks!
What is the difference between st_transform and transform?
I notice that both are wotking for me.
Regards,
/Magnus, SMHI
-----Ursprungligt meddelande-----
Från: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] För Obe, Regina
Skickat: den 13 december 2007 14:29
Till: PostGIS Users Discussion
Ämne: RE: [postgis-users] Change projection in select?
SELECT AsText(ST_Transform(geom, 3021)) FROM mytable
If you are using a pre-1.2 install of PostGIS you may need to use
transform(geom,3021) instead of st_transform(geom,3021)
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Runesson Magnus
Sent: Thursday, December 13, 2007 8:22 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Change projection in select?
I have a table where my geometries are saved in SRID 4326. To get my
result in text I do:
SELECT asText(geom) FROM myTable;
Sometimes I want to get my results from the select in 3021 instead. Can
I do that? How do I do that?
Regards,
/Magnus, SMHI
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
