[postgis-users] No Space left on device.
Richard Heimann [C] heimann at ait.nrl.navy.mil
Thu Dec 13 08:31:13 PST 2007
Too easy!! Thanks again Paul.
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Thursday, December 13, 2007 11:23 AM
To: Richard.Heimann at nrl.navy.mil; PostGIS Users Discussion
Subject: Re: [postgis-users] No Space left on device.
Richard,
Move the "data" directory to a new device, and then in
postgresql.conf, alter the location of the default data space to that
location.
P
On 13-Dec-07, at 7:37 AM, Richard Heimann [C] wrote:
> This question is more to do with PostgreSQL then PostGIS but I've
> always gotten good response on this forum and so I'm going back to
> the well.
> After a recent load, I received the following error, ".No space
> left on device SQL State 53100 Hint: Check free Disk Space." This
> error is fairly self-explanatory but I don't know how to approach
> the problem. In SQL server I would simple stop autogrowth on a file
> group, create a new file group on a larger partition and be done or
> alternately attached/detach the database onto new partition and
> begin work again. My point is there are several ways but Im new to
> PostrgeSQL and Im curious - what's the best practice. I believe all
> the data is in the installation directory <data> folder. Can I
> simply move this folder and somehow reattach? Thanks in advance, Rich
> From: Gregory Williamson [mailto:Gregory.Williamson at digitalglobe.com]
> Sent: Tuesday, December 11, 2007 7:48 PM
> To: Richard.Heimann at nrl.navy.mil; PostGIS Users Discussion; Michael
> Smedberg; Richard.Heimann at nrl.navy.mil; PostGIS Users Discussion
> Subject: RE: [postgis-users] HELP adding spatial field to table
> I think it is rare that you'd want corrupt data. My usual approach
> has been to load my data set into a temporary table (only lasts for
> the session (or transaction)) and then apply sanity checks and
> either delete offending rows or modify them if you know sane values
> to set them to.
> Then create the geometries from the data set and insert it into my
> real table, possibly with something like
>   INSERT INTO some_real_table SELECT gid,label_name,the_geom FROM
> foo WHERE IsValid(the_geom);
> HTH,
> Greg W.
> (sorry for top-posting, challenged reader and pressed for time)
> From: postgis-users-bounces at postgis.refractions.net on behalf of
> Richard Heimann [C]
> Sent: Tue 12/11/2007 4:57 PM
> To: 'Michael Smedberg'; Richard.Heimann at nrl.navy.mil; 'PostGIS
> Users Discussion'
> Thanks for the prompt response. And youre right there are some such
> values.
> Is there a work around?
>  Rich
> From: Michael Smedberg [mailto:Michael.Smedberg at redfin.com]
> Sent: Tuesday, December 11, 2007 6:55 PM
> Are you sure that x and y always have legit values?  If one were
> null or
> the zero-length string, I think you'd get an error like that.
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Richard Heimann [C]
> Sent: Tuesday, December 11, 2007 3:44 PM
> To: 'PostGIS Users Discussion'
> Subject: [postgis-users] HELP adding spatial field to table
>  All,
> Im getting some strange behavior that I cant explain and sadly know
> its
> likely trivial. My pursuit is simple, add a spatial filed to a table
> containing x,y.
> First. AddGeometryColumn
>         SELECT AddGeometryColumn( 'crimetest', 'geom', 4326,
> 'POINT', 2)
> Next (and where the trouble lies)
>         UPDATE crimetest
>         SET geom = PointFromText('POINT(' || x || ' ' || y || ')',
> 4326)
> This is the error I receive.
> ERROR: Invalid OGC WKT (too short)
> SQL state: XX000
> Context: SQL function "geomfromtext" statement 1
> SQL function "pointfromtext" statement 1
> Can anyone shed some light on this?
> Thanks
> Rich
> postgis-users mailing list
