[postgis-users] Points-in-polygon performance
    Paul Ramsey
    pramsey at refractions.net
    Thu Dec 20 15:00:15 PST 2007
pggis 1.3+
select t.*
from region_polygons r, geom_table t
where
   st_contains(r.rpg_geom,t.geom_fld)
and
  rpg_name = 'GVRD_OLD'
pgis < 1.3
select t.*
where
   r.rpg_geom && t.geom_fld
and
and
On 20-Dec-07, at 1:48 PM, Robin Chauhan wrote:
> I have a region_polygons table where region_polygons.rpg_geom is a
> MULTIPOLYGON.
> I want to select rows in the geom_table where geom_table.geom_fld
> is within region_polygons.rpg_geom
> The following idiom works for me, but is waaaay slow (whereas I
> found other kinds of spatial queries are pretty zippy):
> SELECT * from geom_table where EXISTS
>                 (select rpg_id from region_polygons where
>                 geom_fld && rpg_geom and intersects(geom_fld,
> rpg_geom) and rpg_name='GVRD_OLD')
> Where should I start?
> a) Simplify the multipolygon?
> b) Joins instead of EXISTS?
> c) Would putting the literal WK format for the polygon right into
> the SQL query help?
> d) ... or something else?
> Robin R Chauhan
> Pathway Intelligence Inc
> robin at pathwayintelligence.com
> 604-886-3964
> postgis-users mailing list
