[postgis-users] shp2pgsql problem with Leopard
david.techer at davidgis.fr david.techer at davidgis.fr
Sun Dec 30 10:53:43 PST 2007
Well I don't have a Mac at home. Hope someone could help!
--david;
Quoting William Kyngesburye <woklist at kyngchaos.com>:
> It works for me with David Techer's note that the table argument is
> required.  For 64bit mode.  In 32bit mode it indeed fails.
> I checked the symbol names and getopt is internal.  But, in 32bit mode
> there is one case of Apple's UNIX2003 version in there also:
> (__TEXT,__text) external __getopt_internal
> (__TEXT,__text) external _getopt
> (undefined [lazy bound]) external _getopt$UNIX2003 (from libSystem)
> (__TEXT,__text) external _getopt_long
> _getopt$UNIX2003 is probably used in shp2pgsql.  In 64bit mode Apple's
> getopt is not there.
> It looks like Apple's symbol variant magic is the problem.  See this
> link for backgrond on symbol variants:
> http://developer.apple.com/releasenotes/Darwin/SymbolVariantsRelNotes/index.html
> Since 64bit OSX is pure UNIX Conforming, it has no need of symbol
> variants, so _getopt = _getopt, and postgis's getopt overrides it.  But
> in 32bit mode, _getopt gets transformed to the $UNIX2003 variant and is
> used instead of postgis's, yet postgis's still gets linked into the
> binary.  And on Tiger, getopt doesn't have a variant.
> If the two different declarations of getopt are causing the problem, I
> wonder if Apple's getopt will work (it's BSD getopt)?  Or did you
> customize getopt for postgis?
> On Dec 30, 2007, at 11:24 AM, Mark Cave-Ayland wrote:
>> Hi David,
>> I suspect you may be experiencing this problem here:
>> http://postgis.refractions.net/pipermail/postgis-users/2007-December/017893.html. Unfortunately we need someone with some OS X knowledge to work out a solution that can work on all platforms, and devise a patch for it
>> Kind regards,
>> Mark.
>> ILande - Open Source Consultancy
>> http://www.ilande.co.uk
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> The equator is so long, it could encircle the earth completely once.
