[postgis-users] Database Design for many tables
Guido Lemoine guido.lemoine at jrc.it
Fri Jan 5 01:21:59 PST 2007
You may even use different Postgresql/postgis data bases, and
even distributed servers. It just depends what kind of querying
you expect, the nature of the actual data and what the users
and/or admins are allowed to do and where you place (parts of)
the business logic. Seems like you want to handle some raster
data as well, so need to think a bit about interfacing with that
as well.
GL
Mark Cave-Ayland wrote:
>On Fri, 2007-01-05 at 09:53 +0100, Christian Braun wrote:
>>Hi all,
>>I have a question regarding the database design of a PostGIS database.
>>At our institute we are planning to set up a database where all
>>spatial and non spatial data should be held central on a server. We
>>have two different working groups. One works mainly on water projects
>>the other in the cleaner production context.
>>We are planning to setup an intranet interface with QGIS and GRASS in
>>order for the knowledge and needs of the user to work with the data.
>>For data entries by users we want to use pgadmin and phppagadmin. As
>>internet and plublic interface we want to use Mapserver. For
>>documentation a metadatasystem is planned after the ISO19115 where we
>>filter out our needed core elements for the data. Additionally we will
>>implement a search function for keywords to filter out data quite
>>rapidly.
>>For the future we probably get a lot of tables (count > 200) mixed up
>>in different topics and types (spatial and non-spatial).
>>What do you think? Should we create databases for any topic and try to
>>categorise the tables or mix it all together in one database and end
>>up in mess. I think administration in pgadmin suffers with that amount
>>of tables but is always better than on the commandline with psql.
>>Thank you for your comments,
>>Christian
>Hi Christian,
>I have had success in the past by using a single database but by
>categorising the tables into different schemas by function/project. I
>don't see anything wrong with mixing spatial/non-spatial tables within a
>single schema as the database engine sees them all as the same anyway...
>Kind regards,
>Mark.
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Unit: Support to External Security
Via E. Fermi, 1 TP 267 Ispra 21020 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent the
views of the European Commission
