[postgis-users] Problem : Within() incorrectly returns 'false'
Arnaud Lesauvage thewild at freesurf.fr
Mon Jan 8 10:55:29 PST 2007
Martin Davis a écrit :
> I'm not sure about this one.  The test checks out fine in JTS.
> But note that you have some <CR>s in the text of the Polygon geometry
> which occur in the middle of coordinate values, and which if actually
> present in the string cause invalid geometry to be created.  If you're
> running this SQL from a script, then you should closely inspect the
> script to make sure that the cmd is either all on one line or the line
> breaks do not split numeric values.
Hi Martin,
The geometries are stored in tables. I wrote their WKT
representation so that anyone could reproduce the problem.
Have you tried running this in psql ?
I really don't get it here...
