[postgis-users] Problem : Within() incorrectly returns 'false'
Emily Gouge egouge at refractions.net
Mon Jan 8 14:05:12 PST 2007
I tried this out on version 3.0.0 of GEOS and it seems to work correctly:
  ?column? | within
  t        | t
(1 row)
  select * from postgis_full_version();
  POSTGIS="1.1.6" GEOS="3.0.0-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
Maybe you can try upgrading to a newer version of GEOS?
Emily
SELECT GeomFromText('POINT(455663 4973705)',32631) &&
GeomFromText('POLYGON((455634.327007261 4973739.18140708,455640.390824553
4973742.34545851,455649.974963534 4973744.72838799,455655.302230411
4973744.81018619,455666.871609771 4973741.51734043,455673.066844244
4973737.99160574,455682.857256671 4973731.31013028,455696.77629443 4973721.97329467,455713.453957339
4973712.16884477,455721.42334697 4973707.86016838,455737.50239802 4973705.84732456,455748.289255495
4973707.80971155,455768.964516862 4973713.10563678,455789.467434074
4973718.30527948,455809.877573217 4973718.59365931,455816.032949075
4973711.16573985,455819.835126931 4973702.44653788,455824.05944495 4973691.47543162,455824.05944495
4973691.47543162,455828.610407021 4973680.12283995,455830.970634323
4973674.90248145,455833.367228335 4973670.30554483,455838.223766503
4973663.87857158,455853.056176824 4973662.3695754,455866.6601998 4973666.33738459,455872.247284383
4973667.83016243,455891.21742699 4973672.66515592,455904.87965274 4973676.20206359,455925.323306466
4973681.93577574,455931.93236638 4973683.83511874,455963.188375863 4973690.90230387,455986.900652308
4973690.57770489,455999.308881106 4973688.08608035,456006.847072463
4973685.91128035,456013.781894891 4973682.68047389,456020.04917607 4973677.53977996,456028.058802994
4973664.42994524,456032.395247822 4973652.08166202,456034.250253643
4973645.32660031,456037.315382866 4973631.6242598,456038.518126576 4973625.06483024,456039.49606989
4973618.95846064,456041.143946469 4973604.12669801,456041.322480722
4973600.16812515,456041.234269879 4973593.33220285,456040.255579245
4973584.79199929,456038.077220394 4973576.88018093,456031.407673379
4973564.92278014,456022.584091079 4973553.60498374,456015.530632601
4973545.35673604,456011.870844281 4973541.1846865,456001.221309389 4973529.12192161,455991.929965679
4973518.46446974,455982.111242839 4973507.13762537,455975.429739526
4973499.25369943,455968.699421007 4973481.2156405,455968.569127113 4973472.22440673,455968.681690362
4973469.48222644,455968.364280116 4973459.20668792,455964.198441514
4973452.80965392,455957.352768727 4973451.16429375,455950.970005851
4973451.05854393,455925.042572423 4973453.79303565,455920.580033511
4973454.95190268,455916.338152812 4973456.411639,455908.870067239 4973460.36365329,455899.377173016
4973468.20421239,455892.64054911 4973473.70250239,455884.308266302 4973478.59803378,455873.700962084
4973482.45761784,455861.855176683 4973485.90236361,455859.696574931
4973492.55059044,455844.389439454 4973492.39432963,455839.411700775 4973495.34512154,455831.33685203
4973502.9194365,455825.191393046 4973512.52991105,455822.579473065 4973518.00029755,455817.751828832
4973530.0745478,455812.814767254 4973543.24550764,455807.105870701 4973557.06881857,455803.959640509
4973563.64623146,455796.916583005 4973575.41517021,455792.972660989
4973580.26754987,455786.234602819 4973585.77560012,455773.906298319
4973590.19110681,455755.880529301 4973589.95244674,455741.983929337
4973588.07856712,455734.473975748 4973587.00298353,455726.703007087
4973585.92187192,455710.902303958 4973583.8726695,455695.630378757 4973582.19016965,455688.520382506
4973581.56743626,455675.978583625 4973580.92133312,455661.611205371
4973581.95574872,455651.587526438 4973586.21821552,455646.738207892
4973591.31382874,455642.936132872 4973598.59694555,455639.807137755 4973608.4661572,455638.377942947
4973614.49593153,455636.97649546 4973621.32268911,455634.084325749 4973637.51733042,455631.585960851
4973653.17474669,455630.344123986 4973661.50140289,455629.696234567
4973665.93866226,455629.696234567 4973665.93866226,455628.383269606 4973675.5239203,455626.235378731
4973693.34686891,455624.997527166 4973707.75141773,455625.052806357
4973722.19487999,455626.239816571 4973728.34327406,455630.963831745
4973736.33081102,455634.327007261 4973739.18140708))',32631),
Within(GeomFromText('POINT(455663 4973705)',32631),
4973736.33081102,455634.327007261 4973739.18140708))',32631));
Arnaud Lesauvage wrote:
> Martin Davis a écrit :
>> I'm not sure about this one.  The test checks out fine in JTS.
>> But note that you have some <CR>s in the text of the Polygon geometry
>> which occur in the middle of coordinate values, and which if actually
>> present in the string cause invalid geometry to be created.  If you're
>> running this SQL from a script, then you should closely inspect the
>> script to make sure that the cmd is either all on one line or the line
>> breaks do not split numeric values.
> Hi Martin,
> The geometries are stored in tables. I wrote their WKT representation so
> that anyone could reproduce the problem.
> Have you tried running this in psql ?
> I really don't get it here...
> postgis-users mailing list
