[postgis-users] Working with point data from google maps in postgis
Paul Ramsey pramsey at refractions.net
Fri Jan 12 20:39:47 PST 2007
While the maps displayed by Google Maps are in mercator, the Google
Maps API never returns any mercator units, it only returns lat/lon,
so you can just use 4326 as the SRID for your data.
To do distance calculations, use distance_sphere (fast, less
accurate) or distance_spheroid (slow, very accurate).
P
On 12-Jan-07, at 6:33 PM, Rob Young wrote:
> I'm looking to make a small application with google maps and
> postgis, where I would enter spatial data into postgis via an
> interface that would use a (google) map to define lat/long points.
> I'm pretty familiar with databases, and know just enough about
> projection systems to know I don't know that much.  ;)  I am
> concerned about getting the following right, as I know if I don't I
> will be introducing errors into any calculations I attempt with
> postigs queries.
> I'm not completely sure which SRID to use with Google maps point
> data.  I have found the following helpful message, but I was hoping
> to confirm that.
> http://postgis.refractions.net/pipermail/postgis-users/2005-
> November/009920.html
> If google maps does use the GRS 80 projection and a mercator
> projection, which SRID should I use when creating postgis tables to
> store said data?  There are quite a few GRS 80 types in the
> spatial_ref_sys table.  I know enough to know that choosing the
> correct one is important, but am really in the dark as to which one
> I should actually choose!  :)
> Also, I will be interested in doing distance based queries (like
> everyone) on this data once it's in the database.  The postgis
> function length uses the project you associate with the geometry
> data, correct?  And the units of the number it returns is specified
> by the SRID?
> Thanks for the help,
> Robert Y
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070112/4bb86cc2/attachment.html>
