[postgis-users] "Field xx renamed to XX_01"
strk at refractions.net
Wed Jan 17 06:34:38 PST 2007
On Wed, Jan 17, 2007 at 02:42:01PM +0100, Stefan Schwarzer wrote:
> I have from time to time in the server's error_log a couple of lines
> saying that "Field xx renamed to XX_01"... I couldn't find out why,
> The dbf shows the original columns as well as the XX_01 columns....
> Why is that? I re-index the table, re-gist it etc... but still the same.
DBF seem to require uppercase fieldnames, or at least this is what
you usually find inside them so better to conform.
If I recall correctly you can use the -k switch to attempt using
whatever case is in the database.
--strk;
