[postgis-users] "Field xx renamed to XX_01"
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon Jan 22 02:52:07 PST 2007
On Mon, 2007-01-22 at 09:07 +0100, Stefan Schwarzer wrote:
> Yes, I dumped other tables and that was ok. It seems there are only a
> couple of tables out of the 500 or so we have that does it... I
> couldn't figure out any pattern...
Hi Stefan,
I can't recreate this using PostgreSQL 8.1 / PostGIS 1.1.6 on Linux.
Could you try upgrading to PostGIS 1.1.6 (no dump/restore required) and
see if the problem still exists?
Also, can you try your example creating a brand-new database, load the
PostGIS functions, load your table, and then try creating a shapefile
with pgsql2shp? This will help prove that there is no corruption in the
database which could be causing this.
Kind regards,
Mark.
