[postgis-users] Starting the postmaster version8.2: pg_ctl <->postmaster
Obe, Regina robe.dnd at cityofboston.gov
Thu Jan 25 21:53:58 PST 2007
Are you running on Linux?  If you are, it looks like you are missing the start command.  I think the syntax is
/usr/local/pgsql/bin/pg_ctl start -l logfile -D /usr/local/pgsql/data
according to the
http://www.postgresql.org/docs/8.2/interactive/server-start.html
From: postgis-users-bounces at postgis.refractions.net on behalf of Steven De Vriendt
Sent: Thu 1/25/2007 9:25 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Starting the postmaster version8.2: pg_ctl <->postmaster
I've upgraded postgres & postgis to the latest version available.
I used to start the postmaster with the -i flag and -D- flag to
be able to connect from outside.
I see there's no postmaster.exe in version 8.2 of postgresql,
so I use this command: pg_ctl -D "<mydatadirectory>" start.
Yet, I can't connect to my db.
Can someone confirm me this is the way to start the postmaster
in 8.2 ?
Regards,
Steven
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070126/86a66448/attachment.bin>
