[postgis-users] Problem With Geometries and a View
    Leonardo Mateo
    leonardomateo at gmail.com
    Tue Jan 30 05:47:36 PST 2007
Hi everyone, I have a problem trying select geometries from a view. It
raises an "Invalid Geometry' error.
What I'm doing is:
- Create a view from a table with several inner joins and generating
the POINTS in the select sentence, for example:
[CODE]
   create view geom as
    select
	record.oid,
	record.recordid,
	GeomFromText('POINT(' || datax.value || ' ' || datay.value || ')'),
	label.value
    from record
    inner join schema on schema.objectid = record.schemaid
    inner join giscontrol on giscontrol.schemaid = schema.objectid
    inner join step on step.schemaid = schema.objectid
    inner join control on control.stepid = step.objectid and
control.islabel = true
    inner join data as datax on datax.recordid = record.recordid and
datax.controlid = giscontrol.xcontrolid
    inner join data as datay on datay.recordid = record.recordid and
datay.controlid = giscontrol.ycontrolid
    inner join data as label on label.recordid = record.recordid and
label.controlid = control.objectid
    where schema.ismain = true and record.datasetid = 515
    order by recordid;
[/CODE]
 - Then check the view was created with the data I need:
[CODE]
   select * from geom;
[/CODE]
  And results like these:
46051;9105;"010100000048E17A14AE471D40713D0AD7A3704640";"ACEA
PINEROLESE INDUSTRIALE SPA"
46037;9106;"010100000048E17A14AE471D40713D0AD7A3704640";"ITALGAS"
26202;9107;"010100000048E17A14AE471D40713D0AD7A3704640";"SIPTEL"
26203;9108;"010100000048E17A14AE471D40713D0AD7A3704640";"SIPTEL"
26204;9109;"010100000048E17A14AE471D40713D0AD7A3704640";"SIPTEL"
 Which look just fine.
 - Then I try to select the extent of these points with:
 [CODE]
   select extent('the_geom') from geom;
 [/CODE]
  And I got this error:
  ERROR:  parse error - invalid geometry
The weird thing is that if I insert that SELECT sentence into another
table and create a view from that table with something like this:
  [CODE]
    create view geom as Select * from <newtable>
  [/CODE]
The extent is selected properly.
What am I doing wrong? It's driving me nuts.
Thanx a lot in advance.
Leonardo Mateo.
There's no place like ~
