[postgis-users] correcting polygons
Obe, Regina robe.dnd at cityofboston.gov
Mon Jun 4 07:16:17 PDT 2007
What do you get if you do
SELECT distinct srid(buffer(poli,0.0)) as the_srid
FROM Depare_area2
where isvalid(poli) = false and isvalid(buffer(poli,0.0)) = true
If you are using pgadmin3 or something like that - you can look at the
create table statement of your table to see the constraints or expand
the table and go to the constraints section to see the constraints and
associated definition.  Unfortunately I don't know off hand how to see
this information by typing in and sql statement next to writing a fairly
convoluted sql statement against the catalog tables.
Hope this helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Malm
Paul
Sent: Monday, June 04, 2007 9:56 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] correcting polygons
Regina,
It is still the same even if I don't use multi()
If I enter:
SELECT distinct (srid(poli)) as the_srid From Depare_area2;
   I will get only -1
If I enter:
SELECT distinct (srid(the_geom)) as the_srid From Depare_area;
   I will get only -1
I did not understand what you wanted me to do with:
"What does your enforce_srid_poli constraint look like?
It should look something like
 CONSTRAINT enforce_srid_poli CHECK (srid(poli) = -1)"
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
Sent: den 4 juni 2007 15:27
Paul,
Hmm strange I would expect your update to be failing for
enforce_geotype_poli since you are trying to update a POLYGON
constrained field (poli) to a MULTIPOLYGON.  Try getting rid of the
multi function call so change to
UPDATE deparea2 SET poli = buffer(poli, 0.0) WHERE isvalid(poli) = false
AND isvalid(buffer(poli, 0.0)) = true;
OR alternatively change your add to
SELECT AddGeometryColumn('public','deparea2', 'poli', -1,
'MULTIPOLYGON',2);
I'm still puzzled why you are getting an "enforce_srid_poli" error.
Paul
Sent: Monday, June 04, 2007 8:49 AM
Regina,
This is how I created deparea:
CREATE TABLE "public"."deparea" (gid serial PRIMARY KEY,
"id" int4,
"lnam" varchar(17),
"name" varchar(12),
"prim" varchar(1),
"grup" int2,
"rver" int2,
"ruin" varchar(1),
"drval1" float8,
"drval2" float8,
"quasou" varchar(70),
"souacc" float8,
"verdat" int2);
SELECT
AddGeometryColumn('public','deparea','the_geom','-1','MULTIPOLYGON',2);
It is this SQL row that generates the error:
UPDATE deparea2 SET poli = multi(buffer(poli, 0.0)) WHERE isvalid(poli)
= false AND isvalid(buffer(poli, 0.0)) = true;
Regards,
Paul
Regina
Sent: den 4 juni 2007 13:47
The error means that you are trying to insert geometries with a
different SRID than the SRID that you specified for your new table.
Note your new table has an SRID = -1
My guess is that your original deparea table has an SRID different from
-1.
To check try
SELECT distinct(srid(the_geom)) as the_srid FROM deparea
You should only get 1 record unless you have a mixed bag of SRIDs.  Now
whatever that srid is, your add geometry should use that instead of the
-1 you have in place.  So the line
SELECT AddGeometryColumn('public','deparea2', 'poli', '<WHATEVER SRID
YOU GOT ABOVE GOES HERE>', 'POLYGON',2);
Hope that helps,
Regina
Paul
Sent: Monday, June 04, 2007 1:54 AM
Thanks Regina,
If you, or someone else, got the time I would be pleased if you can
explain this error code for me. I've tried to do some random changes :)
since I'm not very good at SQL.
ERROR (appears on the last SQL row):
org.postgresql.util.PSQLException: ERROR: new row for relation
"depare_area2" violates check constraint "enforce_srid_poli"
This is what I do:
SELECT geometryN(the_geom, generate_series(1, numgeometries(the_geom)))
AS poli FROM deparea; CREATE TABLE deparea2 (gid serial, CONSTRAINT
pk_deparea2 PRIMARY KEY(gid));
SELECT AddGeometryColumn('public','deparea2', 'poli', '-1',
'POLYGON',2);
INSERT INTO deparea2(poli) SELECT geometryn(the_geom, generate_series(1,
numgeometries(the_geom))) As poli FROM deparea;
CREATE INDEX idx_deparea2_poli  ON deparea2  USING gist (poli);
Kind regards,
Paul
Regina
Sent: den 1 juni 2007 17:05
Forgot to mention before updating the field, its probably best to only
if you really need to and if updating will help so something like
UPDATE sometable
SET the_geom = multi(buffer(the_geom, 0.0)) WHERE isvalid(the_geom) =
false and isvalid(buffer(the_geom,0.0)) = true
Regina
Sent: Friday, June 01, 2007 8:28 AM
Paul,
Not sure if this quite answers your question, but you would use an
UPDATE statement to update a geometry
So for example
UPDATE sometable SET the_geom = multi(buffer(the_geom, 0.0))
or
UPDATE sometable SET the_geom = buffer(the_geom, 0.0)
Now generate_series explodes a row so in an update statement - doesn't
really make sense to use unless you want to do something with each
individual geometry and then collapse it back using something like
collect or geomunion.  As I recall from using buffer before, I think it
acts on each individual geometry in a multi set e..g in a multipolygon.
So doing a generate series is really not necessary to use buffer - it
sort of implicitly does that whole thing for you.  Someone correct me if
I am wrong on that assumption :)
The only thing to be careful of is that if you have a constraint on your
table that requires the_geom to be say a multipolygon,  when you apply a
buffer operation to it and there is only one geometry within the
multigeometry, buffer will convert that multipolygon to a polygon.  To
prevent that from happening, you would then apply the multi function.
multi function in essence wraps your single polygon into a multipolygon
encasement.
Hope that helps,
Regina
Paul
Sent: Friday, June 01, 2007 4:50 AM
Thanks, Paul!
I'm not to good in SQL and have looked at old userGroup qestions and
found this (Regina Obe):
(converting multi polygons to polygons by creating a new tabel)
String table = "depare_area";
String qq;
myStat = con.createStatement();
qq= "SELECT geometryN(the_geom, generate_series(1,
numgeometries(the_geom))) AS poli FROM " + table; Statement myStat2 =
con.createStatement(); ResultSet myResult2 = myStat2.executeQuery(qq);
qq = "CREATE TABLE " + table + "2 " + "(gid serial, CONSTRAINT " + "pk_"
+ table + "2 " + " PRIMARY KEY(gid))";
myStat.execute(qq);
qq = "SELECT AddGeometryColumn('public','" + table + "2', 'poli', '-1',
'POLYGON',2)"; myStat.execute(qq);
qq = "INSERT INTO " + table + "2(poli) SELECT geometryn(the_geom,
generate_series(1, numgeometries(the_geom))) As poli FROM " + table;
myStat.execute(qq);
qq = "CREATE INDEX idx_" + table + "2_poli  ON " + table + "2  USING
gist (poli)"; myStat.execute(qq);
Du you know how I at the same time can use your suggestion to use
buffer(xxxx, 0.0) to correct the polygons?
I have not found anything of how to update objects, only how to create
new objects.
Kind regards,
Paul
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: den 30 maj 2007 20:01
Subject: Re: [postgis-users] correcting polygons
buffer(polygon,0.0) should re-build it with correct structure
On 30-May-07, at 7:29 AM, Malm Paul wrote:
> Hi list,
> Is there a simple way to correct a polygon that has a hole and where
> one of the coordinates of that hole is exactly the same as one
> coordinate in the external ring?
> Kind regards,
> Paul
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure pursuant
to Massachusetts law. It is intended solely for the addressee. If you
received this in error, please contact the sender and delete the
material from any computer.
