[postgis-users] Problems with making own shape dumper
Paul Ramsey pramsey at refractions.net
Thu Jun 14 14:37:01 PDT 2007
Дорофеев А.В. wrote:
> "Is there any method to get feature coords without ASTEXT() function?"
Let me give you the easy one: to get relatively compact coordinates, in
an easy-to-parse form, use Encode(AsBinary(the_geom),'base64') on the
database side. On the client side, run a base 64 decoder to get a byte
array and then the byte array is a standard well-known-binary array of
coordinates, as described in the SFSQL standard.
P
   Paul Ramsey
   Refractions Research
   http://www.refractions.net
   Phone: 250-383-3022
   Cell: 250-885-0632
