[postgis-users] re:Problems with making own shape dumper
Michael Fuhr mike at fuhr.org
Fri Jun 15 06:46:02 PDT 2007
On Fri, Jun 15, 2007 at 11:01:06AM +0100, Mark Cave-Ayland wrote:
> On Fri, 2007-06-15 at 13:31 +0400, дорофеев александр wrote:
> > I took this shapefile (Arc) and uploaded it into postgis using standart shp2pgsql
> > Then I  tryed to download this data into shapefile using my own dumper and I`ve got an error with spliting string on feature with FID=7. Then i dumped this geometry string into textfile and got this (brokenstring.txt)
> > then i made biggeom.sql and run it in psql to see if a string will be broken  and all was fine
> > The Developers said than it is a bug of ODBC driver. I checked this sugggestion by addind text field to postgis table and run such sql UPDATE testtable SET testfield=ASTEXT(the_geom) and the string in this field became broken (maybe not finished) on small objects the value of this field looked well
> Everything looks fine here.
Here too.  I notice that brokenstring.txt becomes broken at right
around 8192 (0x2000) bytes, which seems like a "neat" number.  Buffer
size in the driver or application?
00001fe0  35 2e 30 33 33 32 33 34  2c 33 34 2e 30 30 34 35  |5.033234,34.0045|
00001ff0  38 35 20 34 35 2e 30 33  30 32 33 39 2c 33 20 20  |85 45.030239,3  |
00002000  20 20 20 20 04 20 20 20  01 20 20 20 20 20 20 20  |    .   .       |
00002010  20 20 20 20 04 20 20 20  1e 02 20 20 20 20 20 20  |    .   ..      |
00002020  20 20 20 20 10 20 20 20  3f 69 3f 3f 3f 3f 3f 3f  |    .   ?i??????|
00002030  3f 3f 3f 3f 3f 3f 3f 3f  20 20 20 20 20           |????????     |
Michael Fuhr
