[postgis-users] docs
Brent Wood pcreso at pcreso.com
Tue May 1 00:45:47 PDT 2007
--- Michael Welter <mike at telecommatters.net> wrote:
> Where can I find docs for the PostGIS software?
> For example, Contains(Polygon,Point) always returns false, but
> Contains(Polygon,Polygon) returns the appropriate boolean.
Do you have examples? That is not what I get:
baw=# select contains(geomfromtext('POLYGON((0 0,0 2,2 2,2 0,0
0))',4326),geomfromtext('POINT(1 1)',4326));
 contains
 t
(1 row)
0))',4326),geomfromtext('POINT(-1 1)',4326));
 contains
 f
(1 row)
Thus true when the point is inside & false when it isn't, as it should be.
> Is there a document that specifies this?
There are two documents that are relevant, the PostGIS docs at www.postgis.org,
but also the SFS whitepaper at:
http://www.opengeospatial.org/standards/sfs
which more fully defines the SFS functions which are implemented by PostGIS.
Cheers,
  Brent Wood
