[postgis-users] Buffer Function
Will Muir will at mtintouch.net
Wed May 2 16:44:38 PDT 2007
Hello, I am a somewhat newbie to sql in general, and I am having some
troubles with the buffer() function.   I am trying to build a table
using the buffer function, with an "insert select" from a table that
was built using shp2pgsql.   The table schematics are as follows.
	 CREATE TABLE spray_buffer (gid INT4 PRIMARY KEY,"name" VARCHAR(32));
	 SELECT AddGeometryColumn
('','spray_buffer','the_geom','-1','POLYGON',2);
When I run the following insert statement,
	INSERT INTO "spray_buffer" (gid,"name",the_geom) SELECT
gid,"name",buffer("the_geom" \
   	,27.432) FROM "spray" WHERE "name" = 'ACTIVE LOG #3';
I get the following error,
	ERROR:  new row for relation "spray_buffer" violates check
constraint "enforce_geotype_the_geom"
Running SELECT version(); returns the following,
	PostgreSQL 8.2.4 on powerpc-apple-darwin8.9.0, compiled by GCC
powerpc-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc.
build 5247)
and running SELECT postgis_version(); returns,
	            postgis_version
	1.2 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
I am trying to view the results in Qgis, when I use the Qgis buffer
plugin I also get a similar error in my log files.  I realize that
the problem is  most likely with declaring the gid as a primary key,
but without that Qgis does not recognize the table.  If it would help
I could post the relevant snippets from the logs.  Any help that
someone could offer would be appreciated.
Thanks,
Will
